Meister
Posted: Mon Apr 28, 2014 9:46 am Post subject: Attiny841 strange behaviour in Bascom |
I am now trying to get an Attiny841 application working. Because of the many Timers and Port options I hoped that might replace two other Tinys that are used presently.
Since examples are rare and rather written in C (but working) I started with programming in C and using CodevisionAVR (eval). With that I could get the timers (CTC and PWM modes) working as they should. Then I converted the Port and Register settings to Bascom directives and got that:
Code: | $regfile = "attiny841.dat"
$crystal = 8000000
$hwstack = 40
$swstack = 16
$framesize = 32
'$baud = 57600
'Disable Interrupts
Puea = 0
Porta = 0
Tocpmcoe = &B0011_1110
Ddra = &B0011_1100
Tccr0a = &B0101_0010
Tccr0b = &B0000_0001
Set Tccr0b.6
Tcnt0 = 0
Ocr0a = &H03
Ocr0b = Ocr0a
Tocpmsa0 = 0
Tocpmsa1 = &B0000_1010
'Do
'Loop
'End |
That program is not doing right. The most interesting feature is that the high-frequency pulse outputs are chopped with a 29Hz frequency. Using the C-code the HF-pulses are continous.
The core of the problem seems to be related to this:
Commenting out anything but the DDRA= line there is a continous output of that 29Hz.
So just setting the DDR register causes a pulsed output of 29Hz.
Maybe somebody has a suggestion on what is going wrong.
Regards, Meister
Posted: Mon Apr 28, 2014 10:02 am Post subject: |
this is a new supported chip. i did not even received the samples from atmel. you should do 2 things :
- check if programming works (use verify). it could be a setting for your programmer is not right.
- if it works with C, check the registers that are set. and also, try if setting DDRA in your C code gives the same problem! _________________ Mark |
Meister
Posted: Mon Apr 28, 2014 11:46 am Post subject: |
Hi, thanks.
Quote: | - check if programming works (use verify). it could be a setting for your programmer is not right.
Programming always verifies (Studio6.2) and is ok.
This Bascom Code gives 29Hz on PA3 and PA4:
The same in C-code puts out nothing (0) as it should be.
$crystal = 8000000
$hwstack = 40
$swstack = 16
$framesize = 32
Disable Interrupts
Ddra = &B1111_1111 |
Strange 29Hz.
Regards, Meister |
Posted: Mon Apr 28, 2014 12:19 pm Post subject: |
the code you show here is simple :
Cli ; disable global interrupts
Ldi R23,$FF
Out $001A,R23
that can never be the problem. _________________ Mark |
Posted: Mon Apr 28, 2014 12:20 pm Post subject: |
of course you need to insert an END but i guess you did. _________________ Mark |
Meister
Posted: Mon Apr 28, 2014 12:30 pm Post subject: |
Right, there was an "End". Just had stopped selcting above that line.
But my previous tests showed that there is no difference with End or not with End.
I agree, that assembler code won't be harmful.
So there should be happening something more...
Regards, Meister |
Meister
Posted: Mon Apr 28, 2014 12:34 pm Post subject: |
Without the DDRA= ... the outputs are quiet.
In this Chip the outputs are muxed to several pins. Maybe the problem comes from that.
Regards, Meister
Posted: Mon Apr 28, 2014 12:37 pm Post subject: |
there is not much more.
stack is set up
watchdog is disabled
ram is cleared. (try $noramclear)
that is it. _________________ Mark |
Posted: Mon Apr 28, 2014 12:40 pm Post subject: |
like i said :
;##### DDRA = &B1111_1111
Ldi R23,$FF
Out $001A,R23
I can not imagine that is wrong. But as i asked before : if you do that in C , you do not get the problem?
show the C code. and possible the asm it create for setting ddr.
beside from the register i can not imagine it can be done otherwise.
atmel inc file : .equ DDRA = 0x1A ;
so the address is right.
maybe the code also set the PORT ? _________________ Mark |
Meister
Posted: Mon Apr 28, 2014 12:42 pm Post subject: |
The full code with $noramclear (doesn't help).
$crystal = 8000000
$hwstack = 40
$swstack = 16
$framesize = 32
'$baud = 57600
$noramclear
Disable Interrupts
'Puea = 0
'Porta = 0
'Tocpmcoe = &B0000_0000
Ddra = &B1111_1111
'Tccr0a = &B0101_0010
'Tccr0b = &B0000_0001
'Set Tccr0b.6
'Tcnt0 = 0
'Ocr0a = &H03
'Ocr0b = Ocr0a
'Tocpmsa0 = 0
'Tocpmsa1 = &B0000_1010
'Do
'Loop
End |
Regards, Meister |
Meister
Posted: Mon Apr 28, 2014 1:18 pm Post subject: |
Very strange. I have a Logicanalyser connected to PA3 and PA4. Then I get the 29Hz pulses when using the Bascom Code. I do not get those pulses when using the equivalent C-Code.
Now, I disconnect the Logicanalyzer. Then (on oscilloscope) the pulses disappear -and come back when reconnecting. The LA-Input disconnected outputs 3V. So probably those are working against eachother. But a LA is legitimate to be connected, its impedance should not be low.
So the Port settings must be different between the Bascom and the C-Program.
Any further help appreciated, Meister |
Posted: Mon Apr 28, 2014 1:27 pm Post subject: |
the real strange thing is that i asked for the C code and the asm but still did not get it. how can i compare it than?
are you aware that this tiny uses the PUD for pull up? _________________ Mark |
Meister
Posted: Mon Apr 28, 2014 1:28 pm Post subject: |
The C-program:
Code: |
#include <tiny841.h>
//#include <io.h>
void main(void)
DDRA=0xff ;
while (1)
// Please write your application code here
Assembler attached.
Regards, Meister |
Posted: Mon Apr 28, 2014 1:38 pm Post subject: |
that code does not do a thing.
better load it in studio and have a look there at the asm.
the text you sent is all remarked. so it is the same as doing in bascom
' DDRA=&HFF
^ notice the remark. this will give the same effect in bascom _________________ Mark |
Meister
Posted: Mon Apr 28, 2014 2:43 pm Post subject: |
Hi Mark,
I try to summerize up to this point:
In my first post I had posted a code that produced those 29Hz chopped HF pulse trains.
That was line by line translated from C, including the PUE register.
Unlike the C-program, only the Bascom output was chopped.
However, the PUE register setting can be omitted in the C-program and everything still works.
Then I stripped down the code to just the DDRA=.. line (so, doing "nothing").
But already with that we have different results with the C and Bascom (getting 29Hz pulses when the LA is connected to the pins, with Bascom-code, not with C).
Here is the Assembler code from the C-code obtained from Studio.
Code: | --- No source file -------------------------------------------------------------
0000001E RJMP PC-0x001E Relative jump
0000001F CLI Global Interrupt Disable
00000020 CLR R30 Clear Register
00000021 OUT 0x1C,R30 Out to I/O location
00000022 OUT 0x35,R30 Out to I/O location
00000023 LDI R24,0x0D Load immediate
00000024 LDI R26,0x02 Load immediate
00000025 CLR R27 Clear Register
00000026 ST X+,R30 Store indirect and postincrement
00000027 DEC R24 Decrement
00000028 BRNE PC-0x02 Branch if not equal
00000029 LDI R24,0x00 Load immediate
0000002A LDI R25,0x02 Load immediate
0000002B LDI R26,0x00 Load immediate
0000002C LDI R27,0x01 Load immediate
0000002D ST X+,R30 Store indirect and postincrement
0000002E SBIW R24,0x01 Subtract immediate from word
0000002F BRNE PC-0x02 Branch if not equal
00000030 LDI R30,0x00 Load immediate
00000031 OUT 0x13,R30 Out to I/O location
00000032 OUT 0x14,R30 Out to I/O location
00000033 OUT 0x15,R30 Out to I/O location
00000034 SER R30 Set Register
00000035 OUT 0x3D,R30 Out to I/O location
00000036 LDI R30,0x02 Load immediate
00000037 OUT 0x3E,R30 Out to I/O location
00000038 LDI R28,0x80 Load immediate
00000039 LDI R29,0x01 Load immediate
0000003A RJMP PC+0x0001 Relative jump
--- D:\cvavreval\Attiny841\Attiny841baretest.c ---------------------------------
DDRA=0xff ;
0000003B SER R30 Set Register
0000003C OUT 0x1A,R30 Out to I/O location
0000003D RJMP PC-0x0000 Relative jump |
Thank you for help. Regards, Meister |
