wait vs timer
Goto page Previous  1, 2
jodank
PostPosted: Sun Apr 27, 2014 2:08 pm    Post subject: Reply with quote
Hey man! You did the whole software.? Smile
Thanks man!
I think to use 8Mhz crystal but I think the internal oscillator should do the job too. Or?
PostPosted: Sun Apr 27, 2014 2:26 pm    Post subject: Reply with quote
You can try but the internal oscillator is not very accurate. For short procedures is sufficient but I would advise here external oscillator. Therefore, Timer 1 is loaded into a constant. It can be changed when you change the frequency.
Enjoy. The software requires a few more thoughts. Deleting variables may be another key, also need to think out what the variable Hours after eight hours.
jodank
PostPosted: Sun Apr 27, 2014 2:35 pm    Post subject: Reply with quote
I finished before this software with the wait function but as I told I figured out does it would be better to made it with the timer function but I'm not so familiar with it and therefore I will learn how to use the timer and I stuck with the prescaler. ..
I will try and make mods on your software and share the result with you here.
I'm very happy for the code which you shared with as.
Thanks man. .. Smile
PostPosted: Sun Apr 27, 2014 2:44 pm    Post subject: Reply with quote
I write It by night and when now look into code i see so instruction "Incr Hours" must be after "End select" of Hours and before Writing to Eeprom
Time_check:
Select Case Minutes
 Case 60 To 80                                              'betwen 50 - 70 min including ofset
 If Countdown = 0 Then
  If Minutes < 70 Then
   Help = 70 - Minutes
   Minutes = 10 - Help
  Elseif Minutes > 70 Then
   Help = Minutes - 70
   Minutes = 10 + Help
    Countdown = 49                                          ' and only after 50 min
   Select Case Hours
    Case 1
     Reset Portb.0
    Case 2
     Reset Portb.1
    Case 3
     Reset Portb.2
    Case 4
     Reset Portb.3
    Case 5
     Reset Portb.4
    Case 6
     Reset Portb.5
    Case 7
     Reset Portb.6
    Case 8
     Reset Portb.7
   B_port = Portb                                           'read port to value
   Incr Hours                                               'next LED can be trigged
   Writeeeprom B_port , 4
   Writeeeprom Hours , 2
   Waitms 50
And once again ->try calculator bullit in MkAVcalculator. Is "userfriendly" Show all possibilites for desired freq/interval/osc output and prescalers. Is not mine Very Happy but this is cool staff and easy to use and understand timers
jodank
PostPosted: Tue Apr 29, 2014 4:28 am    Post subject: Reply with quote
Can somebody help me to solve the problem with this code:
$regfile = "2313def.dat"
$hwstack=40
$swstack=16
$framesize = 32
const Timer1Reload = 7812
Config Timer1 = Timer , Prescale = 1024
Config Portb.0 = Output
load timer1 , Timer1Reload
on ovf1 Timer1_isr
enable timer1
Start Timer1
enable interrupts
Portb.0 = 1
Timer1_ISR:
   load timer1, Timer1Reload
    If Portb.0 = 1 Then
      Portb.0 = 0
      Waitms 500
      Portb.0 = 1
      Waitms 500
  return
I try to toggle the led on portb.0 pin but nothing is going on and off...
Sad
PostPosted: Tue Apr 29, 2014 1:42 pm    Post subject: Reply with quote
In interrupts routines we try to not using ANY delay.
For this "job" a Time to interrupt should be delay.
In your code Return instruction dont have place to return Very Happy
Try this
$crystal = 8000000                                          'remember that calculations are for this freq
$hwstack=40
$swstack=16
$framesize = 32
Config Portb.0 = Output : Portb.0 = 1
Config Portb.1 = Output : Portb.0 = 1
Const Timer1reload = 61631                                  'this should be 500ms
Enable Timer1 : On Timer1 Timer1_isr
'***** start o neverending loop *****
'***** end of loop **********
Timer1_isr:
  Timer1 = Timer1reload
   Toggle Portb.0                                           'toggle change state of pin
   Portb.1 = Not Portb.1                                    'this is the same
  Return                                                    ' return to what? In your code no place to return
One question in the end. Do you change fusebit DIV8 ? (dividing by 8 setted factory) If not your Freq is 1MHz and LED blink slowly Wink
jodank
PostPosted: Wed Apr 30, 2014 10:17 am    Post subject: Reply with quote
Thank's for the advice.
I put the wait function into the isr routine because I was very frustrated Smile and I put it just in...
The main problem is the do - loop. I didn't give the program to do something but runs through the whole program and through the isr process. Smile
Page 2 of 2
