bibibo
Posted: Thu Apr 24, 2014 9:44 pm Post subject: SMTP Protocol |
I try to make SMTP communication and i tested with two SMTP servers.
First SMTP server . no problem, working very good
Second SMTP server sends error after command Tcpwrite(idx ,"DATA{013}{010}")
If i send email by telnet, no error appears. I do not know what problem there is.
idx = Getsocket(smtp_email_socket , Sock_stream , 4086 , 0)
If idx = 255 Then print "SMTP Email Getsocket Error"
result = Socketstat(idx , Sel_control )
Select Case result
Case Sock_closed : print "Sock_closedr"
Case Sock_arp : print "SOCK_ARP"
Case Sock_listen : print "SOCK_LISTEN"
Case Sock_synsent : print "SOCK_SYNSENT"
Case Sock_synrecv : print "SOCK_SYNRECV"
Case Sock_established : print "SOCK_ESTABLISHED"
Case Sock_close_wait : print "SOCK_CLOSE_WAIT"
Case Sock_last_ack : print "SOCK_LAST_ACK"
Case Sock_fin_wait : print "SOCK_FIN_WAIT"
Case Sock_closing : print "SOCK_CLOSING"
Case Sock_time_wait : print "SOCK_TIME_WAIT"
Case Sock_init : print "SOCK_INIT"
Case Sock_udp : print "SOCK_UDP"
Case Sock_raw : print "SOCK_RAW"
Case Sock_macraw : print "SOCK_MACRAW"
Case Sock_ppoe : print "SOCK_PPOE"
'connect to smtp server
result = Socketconnect(idx , SMTP_server (1).SMTP_server (2).SMTP_server (3).SMTP_server (4), SMTP_port ) ' smtp server and SMTP port 25
' ^socket
' ^ ip address of the smtp server
' ^ port 25 for smtp
print "Connecting to Email Server: " ; str(SMTP_server (1)) ; "." ; str(SMTP_server (2)) ; "."; str(SMTP_server (3)) ; "." ; str(SMTP_server (4)) ; " Port: " ; str(SMTP_port )
print "Socketconnect Status = " ; result
If result = 1 Then print "ERROR connecting to " ; str(SMTP_server (1)) ; "." ; str(SMTP_server (2)) ; "."; str(SMTP_server (3)) ; "." ; str(SMTP_server (4)) ; " Port: " ; str(SMTP_port )
result = Socketstat(idx , 0) ' get socket status
Loop Until result = Sock_established
print "SMTP = " ; "SOCK_ESTABLISHED"
Tcp_var = Tcpread(idx , email_string ) ' get response from SMTP server
If Left(email_string , 3) = "220" Then
print "Server Answer = " ; email_string
Exit Do
'The Watchdog will restart the micro in case of no or wrong answer
print "Send " ; "HELO Peto{013}{010}"
Tcp_var = Tcpwrite(idx , "HELO Peto{013}{010}" ) ' send username
print Tcp_var ; " bytes written" ' number of bytes actual send
If Left(email_string , 3) = "250" Then
Exit Do
If Len(User ) > 0 Then
print "Send " ; "AUTH LOGIN{013}{010}"
Tcp_var = Tcpwrite(idx , "AUTH LOGIN{013}{010}" ) 'authentication login
If Left(email_string , 3) = "334" Then
Exit Do
Temp_string = Base64enc(User )
'The username must be Base64 encoded (and add the CR + LF)!
Tcp_var = Tcpwritestr(idx , Temp_string, 255 ) 'USERNAME
Exit Do
Temp_string = Base64enc(Pass )
'The password must be Base64 encoded (and add the CR + LF) !
Tcp_var = Tcpwritestr(idx , Temp_string, 255 ) 'PASSWORD
If Left(email_string , 3) = "235" Then
Exit Do
'Your Email address
Tcp_var = Tcpwrite(idx , "MAIL FROM: testemail@test.com{013}{010}")
Exit Do
If instr(RCPT_TO_1, "@") > 0 Then
Temp_string = "RCPT TO: " + RCPT_TO_1 + "{013}{010}"
Tcp_var = Tcpwritestr(idx , Temp_string, 255)
If instr(RCPT_TO_2, "@") > 0 Then
Temp_string = "RCPT TO: " + RCPT_TO_2 + "{013}{010}"
'Print Temp_string
'The Email address you want to send the message to
'Tcp_var = Tcpwritestr(idx , Temp_string, 255)
Exit Do
Tcp_var = Tcpwrite(idx , "DATA{013}{010}{013}{010}" )
Print email_string
If Left(email_string , 3) = "354" Then
Exit Do
Tcp_var = Tcpwrite(idx , "SUBJECT: Remote Relay Control{013}{010}")
If Send_html = 1 Then
'----------------------Send the Email as HTML ---------------------------
Tcp_var = Tcpwrite(idx , "Mime-Version: 1.0;{013}{010}")
Tcp_var = Tcpwrite(idx , "Content-Type: text/html; charset={034}ISO-8859-1{034};{013}{010}")
Tcp_var = Tcpwrite(idx , "Content-Transfer-Encoding: 7bit;{013}{010}")
Tcp_var = Tcpwrite(idx , "{013}{010}") 'Empty line to switch to body
Tcp_var = Tcpwrite(idx , "<html>{013}{010}")
Tcp_var = Tcpwrite(idx , "<body>{013}{010}")
Tcp_var = Tcpwrite(idx , "<h2>Remote Relay Control</h2>{013}{010}")
Tcp_var = Tcpwrite(idx , "</body>{013}{010}")
Tcp_var = Tcpwrite(idx , "</html>{013}{010}")
Tcp_var = Tcpwrite(idx , ".{013}{010}")
'-----------------------Send only TEXT-----------------------------------
Tcp_var = Tcpwrite(idx , "{013}{010}") 'Empty line to switch from subject to body
Tcp_var = Tcpwrite(idx , "Toto je test{013}{010}")
Tcp_var = Tcpwrite(idx , "Ahoj{013}{010}")
length = len(email_string )
Tcp_var = Tcpwrite(idx , email_string, length )
Tcp_var = Tcpwrite(idx , ".{013}{010}") ' end with a single dot
end if
print "Server Answer = " ; email_string '--> 250 2.6.0 Message accepted
Exit Do
print "Send " ; "QUIT{013}{010}"
Tcp_var = Tcpwrite(idx , "QUIT{013}{010}")
If Left(email_string , 3) = "221" Then
Exit Do
Print "Close Socket"
Closesocket Idx ' close the server connection |
MAK3
Posted: Fri Apr 25, 2014 7:02 am Post subject: |
your command in the code is actually
Code: | Tcp_var = Tcpwrite(idx ,"DATA{013}{010}{013}{010}" ) |
Why two times {013}{010} ?
MAK3 |
bibibo
Posted: Fri Apr 25, 2014 8:42 am Post subject: |
Sorry, it was test with two {013}{010}. It also does not work with one {013}{010} |
MAK3
Posted: Fri Apr 25, 2014 10:36 am Post subject: |
What is the server sending back after the DATA command ?
Once you sent the DATA command the server is waiting for input until you send the "."
Quote: | DATA to signal the beginning of the message text; the content of the message, as opposed to its envelope. It consists of a message header and a message body separated by an empty line. DATA is actually a group of commands, and the server replies twice: once to the DATA command proper, to acknowledge that it is ready to receive the text, and the second time after the end-of-data sequence, to either accept or reject the entire message. |
Maybe one Server is more accurate than the other or you need to change the timing (what to send when to this specific server)
Please check also:
http://en.wikipedia.org/wiki/Simple_Mail_Transfer_Protocol
There are lots of reply codes that can come back from Server after DATA comand:
Quote: | DATA replay codes
354 Start mail input; end with <CRLF>.<CRLF>
451 Requested action aborted: local error in processing
554 Transaction failed
500 Syntax error, command unrecognised
501 Syntax error in parameters or arguments
503 Bad sequence of commands
421 <domain> Service not available, closing transmission channel
received data
250 Requested mail action okay, completed
552 Requested mail action aborted: exceeded storage allocation
452 Requested action not taken: insufficient system storage |
bibibo
Posted: Fri Apr 25, 2014 1:31 pm Post subject: |
When atmega sends command Data, the mail server answers
500 5.5.2 Error: bad syntax
503 5.5.0 <DATA>: Data command rejected: Improper use of SMTP command pipelining
I do not know what this means. |
MAK3
bibibo
Posted: Fri Apr 25, 2014 7:32 pm Post subject: |
Hello MAK3,
Thanks a lot. The problem was solved. The problem was in the code below.
End If |
The correct code is
End If |
