jodank
Posted: Tue Apr 22, 2014 2:07 pm Post subject: wait vs timer |
Hi! to all folks...
I have a simple question.
I'm new on avr and Bascom.
I have a small project to do.
Project:
- 8 led's represents each one 1h time
- Human should press a button on every 50-70 min.
If button pressed in the time between 50 - 70 min. then a led goes on.
I wish to use the wait function to measure the time between 0 - 70 min.
I wish to use an INT0 for the input button.
Is the wait function precise enough to make this job or should I use the Timer from my Attiny2313?
Can somebody advice me for what and wen should we use the WAIT function of Bascom if not in case like this?
I'm not really understand the difference between the WAIT and the TIMER function...
Thank's for any advice.
Posted: Tue Apr 22, 2014 5:50 pm Post subject: |
Wait just sits in a tight Loop, incrementing a variable unril a value is reached.
A timer is a Hardware function that Counts CPU ticks allowing the main CPU do something else or sleep (saving power)-
I would recommend using a timer that fires every few seconds, incrementing a Counter until you reach the required time.
Arera
Posted: Tue Apr 22, 2014 5:58 pm Post subject: |
Hi jodank and welcome to this friendly forum!
Your question contains 100 subquestions...
WAIT stops your prog for a given time. That is sometimes useful for microsec to single secs.
Do not wait for an hour!!!!
Timers are powerful and versatile. In your case, I'd suggest following:
Choose the shortest tomeunit you need to resolve. Here this might be one second.
Set one timer to interrupt every second. In the interrupt, increase a word-var. In the main routine, calculate the elapsed time since a button was pushed or anything else.
Think about that, then poke the next question!
Marc |
Arera
Posted: Tue Apr 22, 2014 8:51 pm Post subject: |
Ians and my posts crossed. Ian is THE ONE to ask how to insert a timer for this specific purpose.
Come on Ian, post the link! |
Posted: Tue Apr 22, 2014 9:05 pm Post subject: |
Arera wrote: | Ians and my posts crossed. Ian is THE ONE to ask how to insert a timer for this specific purpose.
Just go over to my web site, Software Tools.
AVRTimer calculates the correct reload values for an AVR timer that fires every x MS and even generates the Bascom code for you.
I was hopeing that my signature would be enough
Posted: Tue Apr 22, 2014 11:56 pm Post subject: |
Hello jodank
The wait is mainly for short delays but it will work but accuracy might be a problem if you have a look in the blog & share your working avr code sections you will find some projects from me in them there is a one second timer that uses the avr clock via an interrupt very good time can be achieved if a crystal or more so if a much higer frequecy crystal oscillator is used and its ouput divided down to run the avr you can see this in my ENC28J60 web server project where the ENC28J60 has a clock output driving the avr that is half of its 25Mhz crystal with this it keeps good time with better than one second per day. Also look at this post http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=10604&highlight=real+clock
Regards Paul |
jodank
Posted: Wed Apr 23, 2014 1:28 am Post subject: |
Ok folks I will try to use the timer function.
I can see that option is better ad I have to learn the timer from AVR too... |
Posted: Thu Apr 24, 2014 8:53 am Post subject: |
I'm interested in what this device works. Is man at work? And what if you do not press a button? Show for which it was not, or only seven leds lights? |
jodank
Posted: Fri Apr 25, 2014 7:27 am Post subject: |
Hi EDC
Yes, the button should press men on work ( night guard ) have to walk around the company and on some points of interest will be mounted one of my device...
If the night guard is missing one hour ( to press the button between 50 & 70 min ) then the led which represent that hour will not fire up.
So on the morning another person will check the result and inform the boss about the situation. |
jodank
Posted: Sat Apr 26, 2014 8:38 pm Post subject: |
Hi folks I'm here again. I stuck with the prescaler stuff. I can't figure out how to get the right prescaler number. I know I should some math do but I'm really stuck with in.
I tried the calculator software which some good people shared her but it won't start. Crashed, don't know why. ..
Can somebody help me with the prescaler no to understand?
Thanks so much. .. |
Posted: Sat Apr 26, 2014 9:13 pm Post subject: |
What error message did you get when AVRTimer crashed? Maybe your missing a DLL or something.
jodank
Posted: Sat Apr 26, 2014 9:20 pm Post subject: |
Right now I'm away from my pc and can't tell you what type of error I got but I will check and text you.
I will check now on the notebook of my girlfriend to see what's going on. . . |
jodank
Posted: Sat Apr 26, 2014 9:41 pm Post subject: |
i.dobson:
Sorry but it's seems it is a problem on my pc.
Right now I tried your calculator on the notebook of my girlfriend and it's work fine.
So, pls sorry...
I will check what is wrong on my pc.
Dif are between this notebook and my pc is in the OS.
On my pc is XP installed and on the notebook is Win7 but I think on my pc is something other wrong... |
Posted: Sat Apr 26, 2014 9:49 pm Post subject: |
No Problems. AVRTimer is written in VB 6.0 and requires several DLL's, that I don't supply with the ZIP.
Just grab the Visual Basic 6.0 runtime files from Microsoft. That should do it.
Posted: Sat Apr 26, 2014 10:14 pm Post subject: |
Hello. Tell us what freq of oscilator you use. In new chip you have Divider by 8 and internal oscillator set by factory so freq is 1MHz.
If you want some other freq for your project then you must change the Fuse bits. I think so is good idea to use this tool http://atnel.pl/mkavrcalculator.html
This is software freeware for popular uC like Tinny2313 and ATmega8. It support many programmers. This tool can read Fuse Bits and "translate" for you to language you can understand then in easy way can change without mistakes like "seting external oscilator" or "disable serial programming" or "use reset pin like port pin".
Inside software is another "stuff" Timer calculator or resistor divider with many calculated value.
Sorry for my english guys
Everyone probably would have done it differently but here's my idea for comparison
$regfile = "2313def.dat"
$Crystal=1000000
$hwstack=40
$swstack=16
$framesize = 32
Config Portb = &B11111111 : Portb = &B11111111 'for LED`s (light On in Low)
Config Portd = &B00000000 : Portd = &B11111111 'inputs for switches
Config Timer1 = Timer , Prescale = 64
Enable Timer1 : On Timer1 Clock 'jump to Clock every second
Const Presettimer1 = 49912 ' value for timer load
Dim Seconds As Byte , Minutes As Byte , Hours As Byte
Dim Countdown As Byte , B_port As Byte , Help As Byte
Waitms 100 'time for port to set properly
If Pind.6 = 0 Then ' If switch pressed on reboot then
Hours = 1 'reset counters
B_port = 255 'all LED`s off
Writeeeprom Hours , 2
Writeeeprom B_port , 4
Waitms 100
Readeeprom Hours , 2 'reached value are saved and restored if power interrupted
Readeeprom B_port , 4
If Hours > 24 Then Hours = 1 'this secure from FF when program is writing
Minutes = 10 ' offset for non Integer use +/- 10min
Portb = B_port 'this light LED`s
'************* START ******************
If Minutes = 81 Then 'if switch not pressed then hour is missed and showed on "LED bar"
Minutes = 21
Incr Hours
Writeeeprom Hours , 2 'only next LED can be trigged
Waitms 50
Countdown = 39 'and only after 40 min (now is 10 min after hour)
Debounce Pind.6 , 0 , Time_check , Sub 'switch to ground
'************ END *********************
Time_check:
Select Case Minutes
Case 60 To 80 'betwen 50 - 70 min including ofset
If Countdown = 0 Then
If Minutes < 70 Then
Help = 70 - Minutes
Minutes = 10 - Help
Elseif Minutes > 70 Then
Help = Minutes - 70
Minutes = 10 + Help
Incr Hours 'next LED can be trigged
Countdown = 49 ' and only after 50 min
Select Case Hours
Case 1
Reset Portb.0
Case 2
Reset Portb.1
Case 3
Reset Portb.2
Case 4
Reset Portb.3
Case 5
Reset Portb.4
Case 6
Reset Portb.5
Case 7
Reset Portb.6
Case 8
Reset Portb.7
B_port = Portb 'read port to value
Waitms 50
Clock:
Timer1 = Presettimer1
Incr Seconds
If Seconds >= 60 Then
Seconds = 0
Incr Minutes
If Countdown > 0 Then Decr Countdown
