Printbin
nil_orally
PostPosted: Tue Apr 22, 2014 1:36 pm    Post subject: Printbin Reply with quote
Hi Folks,
I am flailing about in a serial handling routine, and am trying to get printbin to work.
So I read the RS485 serial string, and take action based on the match in a CASE statement. That writes a few variables and sets flags as required.
Some codes are commands to operate relays and generally set fire to things, and some are requests for information from the board. If it a command the serial port sends a straightforward ack sequence, but if it is a request for info, the length of the response can be variable. All of this is binary data, so I can't use Print.
So the relevant bits of the info processing:
$regfile = "m328pdef.dat"
$hwstack = 80        '32
$swstack = 32        '8
$framesize = 40
dim Rx_buff(20) as Byte
dim rx_string as string * 21 at Rx_buff overlay
dim Tx_buff(20) as Byte , buff_qty as byte
dim tx_string as string * 21 at tx_buff overlay
dim req_tx_reply as bit , std_tx_reply as bit , reply_tx_delay as byte
dim write_relays as Byte , relay_do as bit
     select Case Rx_buff(5)
        case &H01 : write_relays = Rx_buff(6) : set relay_do : set std_tx_reply                'Direct relay control
' yadda
' yadda
        case &H2A : Tx_buff(4) = Rd_23017_0_db : set req_tx_reply : buff_qty = 1         'what is on the digital inputs?
' yadda
' yadda
     End Select
The following gives me a nicely formatted 4 byte output response:
      if std_tx_reply = 1 then                                                            '5-10ms response time
         incr reply_tx_delay
         if reply_tx_delay > 1 then
            reset reply_tx_delay
            reset std_tx_reply
            Tx_buff(1) = Header_d
            Tx_buff(2) = Board_type
            Tx_buff(3) = Rs485_add
            Tx_buff(4) = MSG_ack
            Printbin #1 , Tx_buff(1) ; 4
         end if
This below however is giving a response of 21 bytes. The first 4 are correct, and the rest are garbage (random crud from the balance of the array/string I guess).
      if req_tx_reply = 1 then
         incr reply_tx_delay
            reset req_tx_reply
            buff_qty = buff_qty + 3                                                       'allow for the header, board type and address preamble
            Tx_buff(3) = Rs485_add                                                      'board address
            Printbin #1 , Tx_buff(1) ; buff_qty                                        '4 in this case
         endif
      endif
This section is all inline code. No sub routines.
The way I read the help file on Printbin, I can set the number of bytes sent. If I hard code a number in, I get what I expect. If I use a variable, I seems to print out the entire string. Any ideas on how to correctly approach this?
kimmi
Moderator
PostPosted: Tue Apr 22, 2014 10:40 pm    Post subject: Re: Printbin Reply with quote
Printbin #1 , Tx_buff(1);4 ; buff_qty sent 4 bytes
See the help
/ Kim
View user's profile Visit poster's website MSN Messenger
nil_orally
PostPosted: Tue Apr 22, 2014 10:54 pm    Post subject: Reply with quote
' Morning Kimmi, (at least it is here).
I did avail myself of the help over several cups of coffee, but that is what got me to here.
I guess my question is does the number (in this case 4, but there will be others as the string is variable length) have to be hard-coded in or can it be a variable so i can do it in a semi-clever way, rather than another tree tree of case statements?
kimmi
Moderator
PostPosted: Wed Apr 23, 2014 12:43 am    Post subject: Reply with quote
printbin does not accept a variable to specify the amount of bytes to print.
/ Kim
nil_orally
PostPosted: Wed Apr 23, 2014 1:21 am    Post subject: Reply with quote
Thanks for the advice, Kimmi.
This works:
         incr reply_tx_delay
            reset req_tx_reply
            select case buff_qty
               Case 4 : Printbin #1 , Tx_buff(1) ; 4
               Case 5 : Printbin #1 , Tx_buff(1) ; 5
               Case 6 : Printbin #1 , Tx_buff(1) ; 6
               Case 7 : Printbin #1 , Tx_buff(1) ; 7
               Case 8 : Printbin #1 , Tx_buff(1) ; 8
               Case 9 : Printbin #1 , Tx_buff(1) ; 9
               Case 10 : Printbin #1 , Tx_buff(1) ; 10
               Case 11 : Printbin #1 , Tx_buff(1) ; 11
               Case 12 : Printbin #1 , Tx_buff(1) ; 12
               Case 13 : Printbin #1 , Tx_buff(1) ; 13
               Case 14 : Printbin #1 , Tx_buff(1) ; 14
               Case 15 : Printbin #1 , Tx_buff(1) ; 15
               case 16 : Printbin #1 , Tx_buff(1) ; 16
            end select
         endif
      endif
