Tcpwritestr - write bigger string
bibibo
PostPosted: Thu Apr 17, 2014 8:21 pm    Post subject: Tcpwritestr - write bigger string Reply with quote
How can i write a bigger string ? I have the string with more than 255 characters and i have a problem with displaying in the web browser
   If S = "<select name={034}IN1INACT{034} size={034}1{034}>" Then
      If Input1_output2_status = 0 Then
         S = S + "<option Selected>--</option>"
         S = S + "<option>--</option>"
      If Input1_output2_status = 1 Then
         S = S + "<option Selected>ON-Vystup 1</option>"
         S = S + "<option>ON-Vystup 1</option>"
      If Input1_output2_status = 2 Then
         S = S + "<option Selected>OFF-Vystup 1</option>"
         S = S + "<option>OFF-Vystup 1</option>"
       If Input1_output2_status = 3 Then
         S = S + "<option Selected>ON-Vystup 2</option>"
         S = S + "<option>ON-Vystup 2</option>"
       If Input1_output2_status = 4 Then
         S = S + "<option Selected>OFF-Vystup 2</option>"
         S = S + "<option>OFF-Vystup 2</option>"
       If Input1_output2_status = 5 Then
         S = S + "<option Selected>ON-Vystup 3</option>"
         S = S + "<option>ON-Vystup 3</option>"
       If Input1_output2_status = 6 Then
         S = S + "<option Selected>OFF-Vystup 3</option>"
         S = S + "<option>OFF-Vystup 3</option>"
       If Input1_output2_status = 7 Then
         S = S + "<option Selected>ON-Vystup 4</option>"
         S = S + "<option>ON-Vystup 4</option>"
       If Input1_output2_status = 8 Then
         S = S + "<option Selected>OFF-Vystup 4</option>"
         S = S + "<option>OFF-Vystup 4</option>"
      If Input1_output2_status = 9 Then
         S = S + "<option Selected>Restart</option></select>"
         S = S + "<option>Restart</option></select>"
Tempw = Tcpwritestr(i , S, 255 )
PostPosted: Thu Apr 17, 2014 9:52 pm    Post subject: Reply with quote
do you use $bigstrings ? that would be required. or specify the lib with $lib "bigstrings.lbx"
you also need a special version of the lib that will send a big string. you can contact support for that.
a simpler alternative :
- send the string in pieces.
