If i change IP address through web browser, the function POST returns me string e.g. 192.168.1.1 How can i simple convert string to IP address and write to variables MyIP ?
Dim Theip(4)asstring*3 Dim Count asbyte Dim Thatip asstring*20
Thatip ="192.168.212.121"
Count=split(Thatip, Theip(1), ".")
This will put the 4 numbers of the IP into the first four Theip string elements the split command is very powerfull when you are working with a web server it saves searching strings for a character then moving to the position etc it quickly cuts the strings into smaller chunks.
