suibaf
Posted: Sat Apr 05, 2014 6:29 pm Post subject: receive on Uart |
Enviroment work: arduino2560 R3, Bascom avr 2077.
I connected 2560 and pc with rs485. I have Uart1 with buffer:
Code: | Config Serialin1 = Buffered , Size = 100 , Bytematch = All |
and the right interrupt:
Code: | 'Label called when UART receives a char
Serial1bytereceived:
While Ischarwaiting(#2) > 0 'while there are bytes in the buffer
A = 0
A = Inkey(#2)
Print #2 , A
Waitms 10
Wend
Return |
The problem is that when I send from terminal 1 byte es: 5D, it answer with 5D (93). But if I send 5D 5D, it answer with value that i don't understand.
Please, can you explain me waht happen?
Best Regards
(BASCOM-AVR version : 2.0.7.7 ) _________________ Bascom AVR full |
Posted: Sat Apr 05, 2014 9:10 pm Post subject: Re: receive on Uart |
suibaf wrote: | Please, can you explain me waht happen? |
Improper use of the buffered routine and improper use of the ISR-extension Serial1bytereceived.
Bascom contains samples, which show proper use. |
Visovian
Posted: Sun Apr 06, 2014 8:04 am Post subject: |
It seems to me rather reasonless first to make an input buffer an then try to do something after each byte received.
You need no bytematch in your code.
Enable Interrupts 'needed for buffered serial
If Ischarwaiting(#2) = 1 Then 'if there is a byte in the buffer ;;;; Edit: "Then" added
A = Inkey(#2)
Print #2 , A
End |
(According to Bascom help example.)
suibaf
Posted: Sun Apr 06, 2014 9:52 am Post subject: |
Inkey no work in my case because i have zero value on transmission. (According to Bascom help)
And, i have tested your code but no work. In my opinion because i have RS485, timing problem may be. Now i have found a solution but i have problem with printbin. I explain:
Code: | Printbin #2 , Rcv_buff(1) ; Num_byte |
Num_byte = 7, but printbin send on serial all array.
If I replace num_byte with 7 it work perfectly. Is it not possible to pass to printbin a variable that specify number byte?
Thanks and best regards[/quote] _________________ Bascom AVR full |
Visovian
Posted: Sun Apr 06, 2014 11:18 am Post subject: |
Quote: | Is it not possible to pass to printbin a variable that specify number byte? |
You can use for example
Code: | For I = 1 To Num_byte
Printbin Rcv_buff(i) ; 1
suibaf
Posted: Sun Apr 06, 2014 11:42 am Post subject: |
Yes that is a solution!
But why it no possible topass to printbin the number of byte with a variable? And if it is no possible, why Bascom does not warn? _________________ Bascom AVR full |
Visovian
Posted: Sun Apr 06, 2014 12:12 pm Post subject: |
Quote: | But why it no possible topass to printbin the number of byte with a variable? |
Simply because Bascom cannot do everything that comes to one's mind.
Bascom supposes (just like the other languages) that user will himself write nonincluded functions.
Quote: | if it is no possible, why Bascom does not warn? |
But it is clearly described in Bascom-help:
PRINTBIN
The number of bytes to send can be specified by an additional numeric parameter. |
Visovian
Posted: Sun Apr 06, 2014 1:07 pm Post subject: |
If you ask why a compilation error is not reported, it is because there is no syntax error.
It is a valid code. It means:
Printbin whole array Rcv_buff() , then Printbin value of variable Num_byte. |
suibaf
Posted: Sun Apr 06, 2014 2:42 pm Post subject: |
Visovian, thank you very mach for your help!
Best Regards
Fabio _________________ Bascom AVR full |
Visovian
Posted: Sun Apr 06, 2014 3:55 pm Post subject: |
Good Luck! |
suibaf
Posted: Tue Apr 15, 2014 10:40 am Post subject: |
In Bascom help, config serialin there is:
When using the BYTEMATCH option, you must preserve the registers you alter.
What does it mean? Can you explain me please? _________________ Bascom AVR full |
Posted: Tue Apr 15, 2014 9:09 pm Post subject: |
the buffered routines are interrupt driven. only the used registers are saved. the bytematch was just intended to set some flag so a user known that some data was received.
in such a case you do not need to do a thing.
but some write complete apps inside this byte match interrupt which destroys registers which are not saved. in such a case, use pushall/popall to make sure you do not destroy regs during the interrupt.
and remember : keep the time in the byte match small since otherwise you might miss data. _________________ Mark |
