Speedometer prescaler
PostPosted: Thu Mar 27, 2014 12:14 am    Post subject: Speedometer prescaler Reply with quote
Hello. With my friend we made a "buggy car" based on Fiat Seicento parts. After installing bigger tyres the speed showed is incorrect.
I want to build a device to incrase pulses from speed sensor. Im thinking about idea how to due this from two weeks Very Happy
It must be something like "freq measure->prescale->freq generation". Prescale may be constant in code - non adjustable for simplicity.
It can be made with ~1s buffer For example if in 1s count 3 pulses i want to 4 pulses in next second on output but if car stopped i dont want any pulses.
If any one have somme idea please post. I need a "spark" Very Happy
Thanks for any reply.
kimmi
Moderator
PostPosted: Thu Mar 27, 2014 12:31 am    Post subject: Reply with quote
An "spark" , try use the forum search for Speedometer Idea
/ Kim
View user's profile Visit poster's website MSN Messenger
JC
PostPosted: Thu Mar 27, 2014 2:07 am    Post subject: Reply with quote
If you have access to a speed sensor signal, then I think I would either use input capture or count pulses for a given time, depending upon the pulse rate, calculate the speed, and display in on an LCD.
JC
PostPosted: Thu Mar 27, 2014 2:35 pm    Post subject: Reply with quote
Thanks for reply. Its my fault and now I read them all, but I thing my problem is different.
I dont want to shoot for a fly with a cannon Very Happy so want use small Tinny2313.
I dont need to display any value. I want calculate new higher speed and send it to output for drive speedometer.
To the sensor goes 3 wire . Earth, supply and return signal. Device can by mounted betwen speedometer and sensor.
I have no idea how calculate pulses for output "in the fly" Eg. If counted value = 0 then I can stop the Timer1 for no pulses.
But how to configure it and load values for generate 3,4,5 and more pulses for next sec?
$regfile = "attiny2313.dat"
$crystal = 8000000
Config Portb = &B00000000 : Portb = &B11111111
Config Portd = &B00000000 : Portd = &B11111111
Config Porta = &B00000000 : Porta = &B11111111
Config Timer0 = Timer , Prescale = 1024                     ' I use TIMER0 for spare TIMER1 to generate
Enable Timer0 : On Timer0 Int_10ms                          'output pulse
Config Int0 = Falling
Enable Int0 : On Int0 Sensor                                'input for sensor pulses
Dim F_10ms As Bit , F_1s As Bit , Ms_counter As Byte        'for 1s timing
Dim S_pulses As Word , Counted As Word , O_pulses As Word   'for counting and calculating pulses
'--------------Setings flag for 1s procedure to spare Timer1--
If F_10ms = 1 Then
   F_10ms = 0
   Incr Ms_counter
   If Ms_counter = 100 Then
      Ms_counter = 0
      Set F_1s
'-------------- Flag 1s is set -----------------------------
If F_1s = 1 Then
   F_1s = 0
 Counted = S_pulses
 S_pulses = 0
 O_pulses = Counted * 1.1                                   'O_pulses is desired pulse for output
 'How to calculate values for pulsing on output for next second?
Sensor:
Incr S_pulses
Int_10ms:
Timer0 = 179
Set F_10ms
PostPosted: Thu Mar 27, 2014 3:27 pm    Post subject: Reply with quote
Okay..that code work. If any one can optimize this, will be great.
It use 95% of flash space.
$crystal = 8000000
Config Portb = &B00001000 : Portb = &B11111111
Config Timer1 = Timer , Prescale = 256
Enable Timer1 : On Timer1 Timer1_int
Output_pin Alias Portb.3
Dim S_pulses As Word , Counted As Word , O_pulses As Single 'for counting and calculating pulses
Dim X As Word , Y As Single , Multiplier As Single
Dim Switch As Bit
Switch = 0
Readeeprom Multiplier , 2
'---Setings flag for 1s procedure to spare Timer1--
If F_10ms = 1 Then
   F_10ms = 0
   Incr Ms_counter
      Ms_counter = 0
      Set F_1s
If F_1s = 1 Then
   F_1s = 0
 Counted = S_pulses
 S_pulses = 0
 If Counted <> 0 Then                                       'for non divide by 0
 O_pulses = Counted * Multiplier
 O_pulses = O_pulses * 2
 Y = 34288 / O_pulses
 X = 35536 - Y
  If Pinb.5 = 0 And Switch = 0 Then
   Switch = 1
   Multiplier = Multiplier + 0.1
   Writeeeprom Multiplier , 2
  Else
   Switch = 0
  If Pinb.6 = 0 And Switch = 0 Then
   Switch = 1
   Multiplier = Multiplier - 0.1
  Else
   Switch = 0
Sensor:
Incr S_pulses
Int_10ms:
Timer0 = 179
Set F_10ms
Timer1_int:
Timer1 = X
If Counted <> 0 Then Toggle Output_pin Else Output_pin = 1
..any tips?
aphawk
PostPosted: Fri Mar 28, 2014 5:44 am    Post subject: Reply with quote
Your problem is math with single variables.
If you can make the math using only byte and word type variables, the program will be small. I had one reduction from about 800 bytes in a program that i made some tricks to not use Single variables.
What is the maximum size that S_Pulses can be ?
Paulo
PostPosted: Fri Mar 28, 2014 9:07 am    Post subject: Reply with quote
S_pulses should contain a Byte..if not I can short the time for sampling to 500ms.
Differences in the displayed speed are visible at higher speeds. The max displayed speed is 140 Km/h at now..
This is what we talking about Very Happy HANDMAKE! Very Happy
http://bart-projects.cba.pl/beno.html
