Posted: Fri Jan 31, 2014 11:36 pm Post subject: 2077 official release |
After a lot of work, and later than planned, i can announce that version 2077 is available.
You can get it using the update wiz, or you can download a full setup.
As always, you can make a backup and/or install the software in it's own folder so you can have the old and the new version.
- The help file has categories for I2C, 1WIRE, etc. which should make it more clear.
- dat files for new chips have been added.
- there is a now support for USI and Xmega slave (the i2c slave add on has been updated as well)
- there is a new/alternative i2c master soft lib
- ######################### IMPORTANT ####################################
the crc32 function has been updated. it returned the crc in the wrong byte order. Now it returns it in the right order. BUT
this means you need to change your code. I left the old code in the mcs.lib so you could copy it in and put it in a new lib to maintain code compatibility
But it is best to update your code.
- spimove() has an optional parameter. it has been discussed in this forum
- the editor has a great feature (IMO) when code explorer is active you can get info about code elements like alias, variable and constants, etc. Just press SHIFT and hover the cursor over your code to see what i mean.
- the editor can also show indent lines for structures. it can be a nice visual help. it requires the code explorer to be visible and it is best to 'proper indent' your code.
These 2 options are not 100% optimal. But i did not want to hold it back since it is already useful.
Have fun!
(BASCOM-AVR version : 2.0.7.7 ) _________________ Mark |
Madf
Posted: Sat Feb 01, 2014 7:38 am Post subject: |
Cool!!! Thank you. |
Tiny
Joined: 10 Nov 2010 Posts: 101 Location: The Netherlands
Posted: Sat Feb 01, 2014 9:13 am Post subject: |
Hi MArk,
Very nice, especially the indent for structures, Thanks |
Robert_d1968
Posted: Sat Feb 01, 2014 12:17 pm Post subject: |
Thank you very much,
I'm downloading it now, it looks very nice indeed... |
PeterM
Posted: Sat Feb 01, 2014 1:15 pm Post subject: |
Excellent _________________ Peter |
Plons
Posted: Sat Feb 01, 2014 2:52 pm Post subject: |
I love the indent with lines for structures, .... used to use Programmer's NotePad in case I needed overview.
Nice work Mark !
Nard _________________ Bascom AVR ver 2.0.8.6
nicofer
Posted: Mon Feb 03, 2014 3:38 pm Post subject: |
Bascom Rocks !!
Baie goed !
Nico |
nicofer
Posted: Thu Feb 06, 2014 2:32 pm Post subject: Indent |
After testing it a bit I have one function on my wishlist .
A text block select option .
Not the complete line but only the chars in a selected block , not the text to the end of a line and from beginning of the next line , this will help a lot to move selected text .
K-Edit , crimson editor , and Notepad++ has this function but can not use it with Bascom .
Please check the link http://notepad-plus-plus.org/features/column-mode-editing.html
Kind regards
Nico |
Posted: Tue Feb 11, 2014 10:50 pm Post subject: |
have a look at the next update. _________________ Mark |
astroschmidt
Posted: Sat Feb 22, 2014 12:52 pm Post subject: |
The indent lines and the "code explorer" are really great enhancements.
Thanks Mark for the new functions.
What would be a great enhancement for a future versions would be tabs for each sub or label (like the tabs in Firefox).
If e.g. you want to follow a variable that is used all over the program it would ease the workflow a lot if you simply jump from tab to tab instead of scrolling through a long program.
Roger |
Posted: Sat Feb 22, 2014 5:11 pm Post subject: |
but where is the version I used for my first program ?
Bascom is better and better !
"Merci beaucoup" Mark for all your works |
Posted: Sun Feb 23, 2014 6:08 am Post subject: Excelent job!! |
Mark did an excelent job.
Love this new Shift-function.
Have fun
Ben Zijlstra |
Posted: Mon Mar 03, 2014 10:58 am Post subject: |
astroschmidt wrote: | The indent lines and the "code explorer" are really great enhancements.
Roger |
you might want to try the 'Find Refrences' function from the Code explorer. select a variable, then click right mouse and select 'Find references'. It will give a list under the variable of instances where the variable is referenced. _________________ Mark |
Neill
Posted: Wed Apr 09, 2014 2:03 am Post subject: |
Shout out to Mr Mark Alberts.
Thanks for the new features!!
Yesterday was the first time I got to use 2077 for a few hours.
I really appreciate the indent and explorer features. Certainly saves time and makes it easier to program.
BASCOM, Just gets better and better. |
njepsen
Posted: Thu Apr 17, 2014 6:10 am Post subject: |
Quote: | the editor can also show indent lines for structures. it can be a nice visual help. it requires the code explorer to be visible and it is best to 'proper indent' yo |
How do you get this to work? _________________ Neil |
