Author
Message
nicofer Joined: 01 May 2013 Posts: 90 Location: GRJ
Posted: Fri Jan 17, 2014 9:30 am Post subject: Timer 0 ,2
I know there are lots of posts and info about timers and interrupts but I have a problem with Timer 0 ,2
I use timer 1 as a pwm timer so that leave me Timer 0 or timer 2 for periodic system interrupt,
I also use Config Clock = Soft to use time functions
The cpu is an at90can32 or 128
My problem is that the timer0 count does not increment , and if I try to use timer2 I get the error : 249 ISR already defined SOFTCLOCK
Here is the timer0 config part :
Config Timer0 = Timer , Prescale = 1024
On Ovf0 Time0e
Enable Timer0
The isr
Time0e:
Toggle Yellowled
In the main loop I have :
Print #2 , Tcnt0
for debugging and the value stay on " 0 " - it does not increment , and also the LED does not toggle .
What am I missing to get this running.
The plan is to get an interrupt each time the timer 0 overflow , with a 16 MHz crystal and 1024 prescale and 8 bit count it should be about 60Hz ?
Cheers
Nico
bgardner Joined: 09 Apr 2004 Posts: 46 Location: Everett, WA
Posted: Sun Jan 26, 2014 4:23 am Post subject:
Hi Nico,
Here's how I configure a Timer to do something like what you're doing.
Config Timer2 = Timer , Prescale = 1024 , Clear Timer = 1
On Oc2a Timer2_isr 'point to interrupt routine
'load preset, enable, and start timer2
Ocr2a = &H C3 'configure preset of 125
Enable Oc2a 'enable interrupt
Start Timer2 'and start timer
Hope this helps.
Bob
enniom Joined: 20 Oct 2009 Posts: 537
Posted: Mon Jan 27, 2014 10:46 pm Post subject:
Nico,
do not have the chip to test fully ... but as a minimum I suggest including:
