Posted: Thu Jan 16, 2014 7:48 pm Post subject: W5100 webserver sample
I'm trying to get the W5100 Webserver sample program working but I'm having a problem. Watching on a terminal program, I see the "done" output after the Config TCPIP command but then it seems to freeze. I inserted a print command in the Do Loop to read the socket status to see what that would tell me and the resulting status is 3. The problem is that the W5100 doesn't seem to have 3 as a result of the Socketstat command. When I shut the power off to the circuit, while the power is falling, I get a CLOSED response then a status of 20 - which is socket listening - so I'm stuck. I'm actually using a WIZ810MJ module and it works fine with the SNTP sample for example.
Posted: Thu Jan 16, 2014 8:53 pm Post subject:
Here I am answering my own question. I had to add the chip select to the TCPIP Config command and change the Config to Noint. Seems to be working fine now.
