Posted: Thu Nov 13, 2008 5:57 pm Post subject: Error 8: Out of internal memory
I am trying to write a program that uses some arrays. As a test, I have declared the following arrays: (the program has those lines only)
dim canal_1(4) as byte
canal_1(1) = &H0B
canal_1(2) = &H12
canal_1(3) = &H85
canal_1(4) = 02
dim canal_2(4) as byte
canal_2(1) = &H0B
canal_2(2) = &H12
canal_2(3) = &H85
canal_2(4) = 02
dim canal_3(4) as byte
canal_3(1) = &H0B
canal_3(2) = &H12
canal_3(3) = &H85
canal_3(4) = 02
dim canal_4(4) as byte
canal_4(1) = &H0B
canal_4(2) = &H12
canal_4(3) = &H85
canal_4(4) = 02
dim canal_5(4) as byte
canal_5(1) = &H0B
canal_5(2) = &H12
canal_5(3) = &H85
canal_5(4) = 02
dim canal_6(4) as byte
canal_6(1) = &H0B
canal_6(2) = &H12
canal_6(3) = &H85
canal_6(4) = 02
dim canal_7(4) as byte
canal_7(1) = &H0B
canal_7(2) = &H12
canal_7(3) = &H85
canal_7(4) = 02
dim canal_8(4) as byte '<- program stops here
canal_8(1) = &H0B
canal_8(2) = &H12
canal_8(3) = &H85
canal_8(4) = 02
dim canal_9(4) as byte
canal_9(1) = &H0B
canal_9(2) = &H12
canal_9(3) = &H85
canal_9(4) = 02
end
But when I compile, the program stops where indicated, with Error 8: Out of internal memory. My microcontroller is a 89S52. And I will need to declare much more arrays. What is wrong? Is there any better way to declare arrays, like : dim x(2) as byte = (1 , 2) ?? I am using version 2.0.12 of BASCOM.
