nicofer
Posted: Mon Nov 04, 2013 10:40 am Post subject: SNTP Problem |
I use an old wiznet module in 12c mode - all working 100 % in TCP / IP as web server on LAN and from " outside " the router .
Now I want to use the SNTP function to get the time and I only get a 0 value ??
What am I missing
I use all the standard setup and configs .
Config Tcpip = Int7 , Mac = 00.02.33.34.56.78 , Ip = 192.168.0.241 , Submask = 255.255.255.0 , Gateway = 192.168.0.1 , Localport = 1000 , Tx = &B11 , Rx = &B11 , Twi = 254 , Clock = 400000 , Chip = W3100a
Tempw = Socketstat(i , 0) ' get status
Select Case Tempw
Case Sock_established
' Ppmw1 = 15
Print #2 , " sock_est" ' delete it when it sends to much data to the terminal
' Print #2 , "Listening on socket : " ; I
Lcd "Ready to connect"
And then the sntp code
Ntp:
Print #2 , " NTP "
Tcp_tempb = Getsocket(0 , Sock_dgram , 1000 , 0) ' get socket for UDP mode, specify port 5000
Print #2 , " ntp socket status " ; Tcp_tempb
'IP URA 193.67.79.202
ip_snmp = Maketcp(128.138.140.44)
Ura_snmp = Sntp(0 , Ip_snmp) ' get time from SNTP server
Print #2 , "Ura_snmp " ; Ura_snmp
Closesocket 0
I tried both the NTP server adres above with NTPTool and i get a reply on my pc , all 100 % working.
How long does the sntp( ) function wait for a reply ?
Any help please.
Cheers |
nicofer
Posted: Fri Nov 08, 2013 7:34 am Post subject: |
Hi Ben
Yes I tried your code also - same problem
If I use Tera Term pro and send a " x" to one of the NPT ip's I get a 4 byte reply.
If I do it with easy tcp I get a 3 byte reply from the NTP server.
I am still wondering how long does the function wait for a reply . can it be that the link is a it slow and for that reason the function return 0 ?
Your code is more a low level of the SNTP function but I have the same problem .
I use the wiznet with only one channel but I make sure it is not busy when I start the UDP - NTP request.
Thanks for the help anyway.
Any idea where I can still find some of the IIN 7000 Wiznet modules ? I mod the unit to work in I2c mode .
Cheers |
Posted: Fri Nov 08, 2013 10:18 am Post subject: |
the w5x00 libs check for received data and wait few ms a number of times till an answer is received.
the w3100 lib only checks a fixed amount of time.
if you send an email to support i can send a mod which you can test. _________________ Mark |
nicofer
Posted: Fri Nov 08, 2013 10:36 am Post subject: |
Thanks - will do .
oops - the 3 bytes is not the return bytes but the nr of bytes sent - the rx byte count is 0
Tcp_tempb = Getsocket(0 , 2 , 5000 , 0) ' get socket for UDP mode, specify port 5000
Print #2 , " ntp socket status " ; Tcp_tempb ' I get a " 0" reply here
Result = Udpwritestr(192.168.0.207 , 37 , 0 , Sstr , 255) ' ntp0.nl.net port 37
Print #2 , "UDP geskryf " ; Result ' I get a " 3 " here
Result = Socketstat(0 , 2) ' get number of bytes waiting
Print #2 , "UDP bytes ontvang " ; Result ' get a " 0 " reply here
If Result > 0 Then
Temp = Udpread(0 , Sa(1) , Result) ' read the result
Print #2 , Sa(1) , Sa(2) , Sa(3) , Sa(4)
Must say the Easy TCP/IP (i2c) + Bascom is VERY powerful. - keep up the good work !
Cheers
Nico |
nicofer
Posted: Fri Nov 08, 2013 10:50 am Post subject: |
Here is a screenshot with the time delay - from South Africa - so with a lot of stops and delays .
It is on a 4MB dsl line .
Best might be to make the delay at least double that .
Cheers |
