Luciano
Posted: Sat Jun 08, 2013 7:54 am Post subject: |
you could also use a microSD card formatted FAT32 and AVR-DOS. To use the microSD card
with a PC, just plug the card into a Micro SD-USB Adapter (see attached picture).
Luciano |
Posted: Sat Jun 08, 2013 8:49 am Post subject: |
Luciano,
Luciano wrote: | you could also use a microSD card formatted FAT32 and AVR-DOS. |
these are all feasible technical options, but the actual problem (that's where the TO gives the members a runaround in not mentioning it) is, that the one and most important factor was omitted: it has to be client-friendly.
If I remember right, there was a link from the TO, now seemingly removed by MOD (death from above ), which pointed to a beauty farm/clinic.
Which makes things clearer, as for such a purpose a memory stick or a smart card is client-friendly enough, while any other of the suggested solutions is not. Here it would have been responsibility of the TO to tell this frankly, which I do blame him for not doing it.
@Edit by MOD ... |
atmega64
Posted: Wed Jun 12, 2013 4:00 pm Post subject: |
I apologize if I have not explained well ...
From the Project Agreements should I use a pen drive as a support ...
I want to test the example that we talked about:
http://www.mcselec.com/index.php?option=com_content&task=view&id=279&Itemid=57
I took all the components and designed the circuit ...
I have a small question ...
how should I set the programmer to set the value of the external clock of the micro 16Mhz??
Use AVRDUDESS v.1.2 programmer with AVR ISP mk II ... for example when I use an ATmega32 with quartz 4MHz imposed the fuses: L = H = 0xD9 0xEA and everything is ok ...
but with this new micro (ATMEGA644P clocked at 16MHz) can not seem to find the right settings and the program I part???
Thank you all. |
atmega64
Posted: Thu Jun 13, 2013 7:57 am Post subject: |
According to the Atmel datasheet for AtMega644P, you should use CKSEL = 0111 for external crystal in full swing mode. There is no specific setting for 16 MHz, but that should work from 8-20MHz at Vcc = 5 volts. _________________ Adrian Jansen
atmega64
Posted: Thu Jun 13, 2013 10:46 am Post subject: |
I tried with "FULL SWING OSCILLATOR; START-UP TIME 16KCK+0ms; CRYSTAL OSC: BOD ENABLE; CKSEL = 0111 SUT = 01" and AVRDUDESS works!
a couple of questions ...
- Why, if I want to program directly by BASCOM can not identify the microprocessor??
- I seem slow start the program ... is this normal? |
atmega64
Posted: Thu Jun 13, 2013 3:04 pm Post subject: |
Help....
Because this command:
Print # 1, "RD todo.txt" + Chr (13);
I get the following error:
Error: 42 Numeric parameter expected ["RD todo.txt]
Error: Invalid data type 31 [0011] 0 [13)]] |
kimmi
Posted: Thu Jun 13, 2013 10:44 pm Post subject: |
try change + to ; _________________ / Kim |
atmega64
Posted: Fri Jun 14, 2013 9:20 am Post subject: |
Quote: | Print # 1, "RD todo.txt" + Chr (13); |
resolved by deleting the ""
Quote: | - I seem slow start the program ... is this normal? |
I solved by disabling: "Divide clock by 8 internally; [CKDIV8=0]"
Quote: | - Why, if I want to program directly by BASCOM can not identify the microprocessor?? |
this problem still remains a mystery ...  |
kimmi
Posted: Fri Jun 14, 2013 9:44 am Post subject: |
- you should read the actual help you get.
- you change the topic right in the thread to a new one ? This is not the 'help me with all my problems' topic.
- you do not give good info, how you do you think you will get help? _________________ Mark |
