'GPS Info by doncarlos with atmega128 and PCF8833 display for processing standard NMEA data
$regfile = "m128def.dat"
$crystal = 11059200
$hwstack = 256
$swstack = 256
$framesize = 256
$lib "lcd-pcf8833BR2.lbx"
Config Graphlcd = Color , Controlport = Portc , Cs = 1 , Rs = 0 , Scl = 3 , Sda = 2
'######################## Color definitons ###################################
Const Blue = &B00000011
Const Yellow = &B11111100
Const Red = &B11100000
Const Green = &B00011100
Const Black = &B00000000
Const White = &B11111111
Const Brightgreen = &B00111110
Const Darkgreen = &B00010100
Const Darkred = &B10100000
Const Darkblue = &B00000010
Const Brightblue = &B00011111
Const Orange = &B11111000
Config Com1 = 9600 , Synchrone = 0 , Parity = None , Stopbits = 1 , Databits = 8 , Clockpol = 0
Config Com2 = 9600 , Synchrone = 0 , Parity = None , Stopbits = 1 , Databits = 8 , Clockpol = 0
Config Serialin = Buffered , Size = 250 , Bytematch = 13 ' GPS Buffer
Dim Gps_data_flag As Byte
Dim Strbytes(252) As Byte
Dim Gpsline As String * 251 At Strbytes(1) Overlay ' NMEA sentence holder
Dim Gpsline_t As String * 251
Dim Strlen As Byte
Dim Index As Byte
Dim Chksum As Byte
Dim Gps_chksum As String * 2
Dim Gps_chksum_b As Byte
Dim Dollar As String * 1
Dim Z As Byte
Dim Gps_adatok(21) As String * 15 'Array for storing various GPS data
Dim Gpstime_s As String * 10
Dim Gpsdate_s As String * 10
Dim Gpslat_s As String * 10
Dim Gpslon_s As String * 10
Dim Pos_status As String * 1 , Nofix As Bit
Dim Dms_lat As String * 15 , Dms_long As String * 15
Dim We As String * 1 , Ns As String * 1
Dim Pdop As String * 4 , Hdop As String * 4 , Vdop As String * 4 , Magassag As String * 6 , Sebesseg As String * 7
Dim Fix_type(4) As String * 8 , Fix_szam As Byte
Dim Sat_track As String * 2
Dim Timezone As Byte
Dim Perc As String * 2 , Mp As String * 2 , Ora As String * 2 , Ora_b As Byte 'Time values: min, sec, hour
Dim Nap As String * 2 , Honap As String * 2 , Ev As String * 2 'Date values: date, month, year
Dim Ido As String * 8 , Datum As String * 8
Dim Sentence_count As Byte , Sentence_num As Byte , Satinview As Byte
Dim Szamlalo As Byte , Szamlalo2 As Byte , Cim As Byte , L As Byte , K As Byte , Cim_temp As Byte , Lineindex As Byte 'some indexing values
Dim Satinfo(64)as String * 3 'Array for the PRN display data (PRN, Azimuth, Elevation, SNR)
Dim I As Byte , H As Byte
Dim Index_temp1 As Byte , Index_temp2 As Byte , Dy As Byte , Dx As Byte 'More indexing values
Dim Pr_number As String * 2 , Ele As String * 2 , Azi As String * 3 , Snr As String * 2
Dim Azi_single As Single , Ele_int As Integer
Dim Ticker As Byte
Timezone = 2 'Modify this for setting your timezone
Declare Function Dmtodms(byval Szog_string As String) As String
Declare Sub Skyplot(azimuth As Single , Byval Elevation As Integer , Prn As String * 2 , Byval Ncolor As Byte)
'######################### LCD Init ############################################
Glcdcmd &H21
Glcdcmd &H36
Glcddata &H48 '40 = RGB or 48 = BGR
Open "Com2:" For Binary As #2
Print "Serial1 init"
Print #2 , "Serial2 init"
Setfont Color8x8
Lcdat 63 , 30 , "GPS" , Black , White
Fix_type(1) = "SPS fix"
Fix_type(2) = "DGPS fix"
Fix_type(3) = "PPS fix"
Fix_type(4) = "RTK fix"
Szamlalo = 1
Szamlalo2 = 1
'!!!!!!!!!!!!!!!!!! For now this is the function selector !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
'!!!!!!!!!!!!!!!!! uncomment one of the gotos to select !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
!!!!!!!! a function, if both commented out the text display will run !!!!!!!!!!!!!!!!!!
'Goto Sky
'Goto Prn_snr
Lcdat 4 , 2 , "GPS Ido:" , Black , White
Lcdat 14 , 2 , "Koordinatak:" , Black , White
Lcdat 44 , 2 , "Elev:" , Black , White
Lcdat 54 , 2 , "Speed:" , Black , White
Szoveges:
If Gps_data_flag > 0 Then Gosub Processgps
If Pos_status = "V" Then
If Nofix = 1 Then Goto Szoveges
Nofix = 1
Lcdat 74 , 2 , " NO FIX! " , Black , White
Lcdat 4 , 66 , " " , Black , White
Lcdat 24 , 2 , " " , Black , White
Lcdat 34 , 2 , " " , Black , White
Lcdat 44 , 56 , " " , Black , White 'clearing the display
Lcdat 54 , 56 , " " , Black , White 'this is faster then a cls
Lcdat 64 , 2 , " " , Black , White
Lcdat 94 , 2 , " " , Black , White
Lcdat 104 , 2 , " " , Black , White
Lcdat 114 , 2 , " " , Black , White
Nofix = 0
Ora = Mid(gpstime_s , 1 , 2)
Perc = Mid(gpstime_s , 3 , 2)
Mp = Mid(gpstime_s , 5 , 2)
Nap = Mid(gpsdate_s , 1 , 2)
Honap = Mid(gpsdate_s , 3 , 2)
Ev = Mid(gpsdate_s , 5 , 2)
Ora_b = Val(ora) + Timezone
If Ora_b > 24 Then Ora_b = Ora_b - 24
Ora = Str(ora_b)
Ido = Ora + ":" + Perc + ":" + Mp
Datum = Ev + "." + Honap + "." + Nap
Dms_lat = Dmtodms(gpslat_s)
Dms_long = Dmtodms(gpslon_s)
Lcdat 4 , 66 , Ido , Black , White
Lcdat 24 , 2 , Ns ; " " ; Dms_lat , Black , White
Lcdat 34 , 2 , We ; " " ; Dms_long , Black , White
Lcdat 44 , 56 , Magassag ; "M"
Lcdat 54 , 56 , Sebesseg ; "Km/h"
Lcdat 64 , 2 , "Sat trk: " ; Sat_track
Lcdat 74 , 2 , Fix_type(fix_szam) ; " "
Lcdat 94 , 2 , "PDOP: " ; Pdop ; " "
Lcdat 104 , 2 , "HDOP: " ; Hdop ; " "
Lcdat 114 , 2 , "VDOP: " ; Vdop ; " "
Prn_snr:
Lcdat 4 , 2 , "PRN" , Black , White : Lcdat 4 , 34 , "Ele" , Black , White : Lcdat 4 , 70 , "Azi" , Black , White : Lcdat 4 , 102 , "SNR" , Black , White
For I = 1 To Satinview
For H = 1 To 4
Index_temp1 = I - 1
Index_temp1 = Index_temp1 * 4
Index_temp2 = H + Index_temp1
Dy = I - 1
Dx = H - 1
Dy = Dy * 8 '12
Dy = Dy + 15
Dx = Dx * 35
Dx = Dx + 4
Setfont Color5x5
Lcdat Dy , Dx , Satinfo(index_temp2)
Setfont Color8x8
Next H
Next I
Sky:
Circle(66 , 66) , 60 , Black 'Drawing the skyplot background
Circle(66 , 66) , 40 , Black ' |
Circle(66 , 66) , 20 , Black ' |
Line(66 , 0) -(66 , 132) , Black ' |
Line(0 , 66) -(132 , 66) , Black ' ˇ
Index_temp1 = I - 1
Pr_number = Satinfo(1 + Index_temp1)
Ele = Satinfo(2 + Index_temp1) : Ele_int = Val(ele)
Azi = Satinfo(3 + Index_temp1) : Azi_single = Val(azi)
If Azi_single <> 0 And Ele_int <> 0 And Pr_number <> "" Then
'Call Skyplot(azi_old , Ele_old , Pr_number , White)
Call Skyplot(azi_single , Ele_int , Pr_number , Red)
'Azi_old = Azi_single : Ele_old = Ele_int
Next I
Waitms 250
Serial0charmatch:
Pushall
Incr Gps_data_flag 'Increment the NMEA sentence counter
Popall
Processgps:
Decr Gps_data_flag
Dollar = Inkey() 'Start finding
If Dollar = "" Then Return
Loop Until Dollar = "$"
Input Gpsline Noecho
Strlen = Len(gpsline)
Chksum = 0
Gps_chksum_b = 0
Strlen = Strlen - 3
For Index = 1 To Strlen
Chksum = Chksum Xor Strbytes(index) 'Checksum generation
Next Index
Gps_chksum = Right(gpsline , 2)
Gps_chksum_b = Hexval(gps_chksum)
If Chksum = Gps_chksum_b Then 'If the checksum matches then we can process the right data
Gpsline_t = Left(gpsline , Strlen)
Z = Split(gpsline_t , Gps_adatok(1) , ",")
Select Case Gps_adatok(1)
Case "GPRMC" 'position and time data
Pos_status = Gps_adatok(3)
If Pos_status = "A" Then
Gpstime_s = Gps_adatok(2)
Gpsdate_s = Gps_adatok(10)
Gpslat_s = Gps_adatok(4)
Gpslon_s = Gps_adatok(6)
We = Gps_adatok(7)
Ns = Gps_adatok(5)
Case "GPGGA" 'fix type, tracked sat number and elevation
Fix_szam = Val(gps_adatok(7))
If Fix_szam <> 0 Then Magassag = Gps_adatok(10)
Sat_track = Gps_adatok(8)
Case "GPGSA" 'DOP values
Pdop = Gps_adatok(16)
Hdop = Gps_adatok(17)
Vdop = Left(gps_adatok(18) , 4)
Case "GPVTG" 'speed
Sebesseg = Gps_adatok(8)
Case "GPGSV"
Satinview = Val(gps_adatok(4))
Sentence_count = Val(gps_adatok(2))
Sentence_num = Val(gps_adatok(3))
If Sentence_num <= Sentence_count Then
If Sentence_num = Szamlalo Then
For L = 1 To 4 'Filling up the satinfo array
If Szamlalo2 > Satinview Then
Szamlalo2 = 1
Exit For
For K = 1 To 4
Cim_temp = L - 1
Cim_temp = Cim_temp * 4
Cim = K + Cim_temp
Lineindex = K + Cim_temp
Lineindex = Lineindex + 4
Cim_temp = Sentence_num - 1
Cim_temp = Cim_temp * 16
Cim = Cim + Cim_temp
Satinfo(cim) = Gps_adatok(lineindex)
Next K
Incr Szamlalo2
Next L
If Szamlalo = Sentence_count Then
Szamlalo = 1
Incr Szamlalo
Case Else
Function Dmtodms(szog_string As String) As String 'function to convert the nmea degrees and miutes to degrees minutes and seconds
Local Szogmp As Single
Local Fok_s As String * 3 , Szogperc_s As String * 2 , Szogmp_s As String * 5
If Len(szog_string) = 9 Then
Fok_s = Left(szog_string , 2)
Szogperc_s = Mid(szog_string , 3 , 2)
Szogmp_s = Right(szog_string , 5)
Szogmp_s = "0" + Szogmp_s
Szogmp = Val(szogmp_s)
Szogmp = Szogmp * 60
Szogmp_s = Fusing(szogmp , "#.##")
If Len(szog_string) = 10 Then
Fok_s = Left(szog_string , 3)
Szogperc_s = Mid(szog_string , 4 , 2)
Dmtodms = Fok_s + Chr(127) + Szogperc_s + Chr(39) + Szogmp_s + Chr(34)
End Function
Sub Skyplot(azimuth As Single , Elevation As Integer , Prn As String * 2 , Ncolor As Byte)
Local X As Single , Y As Single
Local X1 As Integer , Y1 As Integer
Local X2 As Integer , Y2 As Integer
Local Azimuth_rad As Single
Local Temp As Single , Temp2 As Single
Temp = Azimuth - 90 'Turning the polar coordinate system with 90°
Azimuth_rad = Deg2rad(temp)
Temp2 = 90 - Elevation 'Inverting the elevation values because for a normal polar coordinate system 90° of elevation would be the furthest and in a skyplot the 90° is the center of the coordinate system
Temp2 = Temp2 * 0.666667 'Scaling down the elevation value because the small screen space
X = Cos(azimuth_rad)
X = X * Temp2 'or * Elevation if you have a bigger screen to work with
X = X + 66
X1 = X
X2 = X1 - 4
Y = Sin(azimuth_rad)
Y = Y * Temp2 'or * Elevation
Y = Y + 63
Y1 = Y
Y2 = Y1 - 4
Lcdat Y2 , X2 , Chr(132) , Ncolor , White 'GPS sat icon drawing
Y2 = Y2 + 9 : X2 = X2 - 1 'PRN number align
Setfont Color5x5
Lcdat Y2 , X2 , Prn 'Prn
Setfont Color8x8
Close #2
'fonts
$include "color8x8.font"
$include "color5x5.font"
