Frankeman
Posted: Sat Oct 02, 2004 8:56 am Post subject: |
Hi Mark,
For your information !
When i started the AutoUpdateWizzard this morning (without the Lic file) the program crached with a RunTime error 216.
(normally this means that a program try to do something the (Delphi) compiler can't catch).
The next time i got a message that no installed product was found (as expected).
Frank. |
Posted: Sat Oct 02, 2004 11:52 pm Post subject: |
Thanks for the info. You should get a message that there is no product installed. So error 216 is strange. Let me know how it works with the lic. _________________ Mark |
randyray
Joined: 03 Oct 2004 Posts: 4 Location: Bedford, Texas USA
Posted: Sun Oct 03, 2004 12:59 am Post subject: Error 216 |
I also get the error 216 when running the wizard. I have the license file in the same directory. |
eddy
Joined: 09 Apr 2004 Posts: 67 Location: Near Chicago, IL USA
Posted: Sun Oct 03, 2004 2:09 am Post subject: |
I had one problem when I ran the update wizzard. Half way through the download/install portion, it stopped and said file not found. I quit the program and restarted, it worked fine the second time.
It looks like the update wizzard doesn't create a start menu shortcut when you install it to a new directory.
Thanks!
Eddy _________________ Eddy Wright
Wright Hobbies, LLC
http://www.wrighthobbies.net |
Christoph Klein
Posted: Sun Oct 03, 2004 8:49 am Post subject: Re: New AutoUpdate Wizzard available for future updates |
> Dear BASCOM user,
> A new utility is available for updating BASCOM(AVR / 8051) and other
> system components.
Hi Mark!
Nice idea, I'm having trouble, though :)
Having copied the LIC file into the updatewizzard's folder I can start the Wiz but keep getting "There are no components found to update".
I would like to install the Beta separetely (it would b.t.w. be helpful if one could create new directories using the Wizzard ...).
The log file:
03-10-2004 09:40:54 >Wizzard started
03-10-2004 09:40:54 >bascom-avr-beta.lic found
03-10-2004 09:41:11 >Check the net
03-10-2004 09:41:12 >checking for new wizzard
Does it matter which LIC file I use (as I received two of them :) )?
Bye,
Christoph |
Posted: Sun Oct 03, 2004 3:22 pm Post subject: |
You should have received only 1 LIC file.
When you recieved more of them, they must be the same. For example when you registered with 2 different email accounts.
The error 216 could be caused by the fact that the exe is packed.
I just uploaded a new version that is not packed. I hope this fix the problem. Make also sure that you can edit the lic file with notepad. ie : that the file is NOT read only.
I have test in W2000, XP SP1 and XP SP2.
Other OS will follow.
The tools is not intended to do a complete install : that is where setup.exe is for. _________________ Mark |
Frankeman
Posted: Sun Oct 03, 2004 4:45 pm Post subject: |
The Runtime error 216 is stil there.
I tried the wizzard without the lic file ! (because i don't received it yet, just curious to see what happens).
Frank.
4Stroke
Posted: Sun Oct 03, 2004 8:22 pm Post subject: |
That's correct...
Mark hasn't send 8051 lic files yet.
Regards,
Nathan |
Juergen Bitzer
Posted: Sun Oct 03, 2004 8:26 pm Post subject: Re: New AutoUpdate Wizzard available for future updates |
I have same problem as Christoph.
The Update doesnt work and shows nothing at all.
I am using Win2K and a proxyserver at linux.
I started different tools at my server (tcpdump, iptraf) and could not find any acces anywhere from the Update-tool to the internet.
Also there comes nothing over out of the ethernet from my Win2K
if i try the tool...
Juergen
Christoph Klein wrote: | > Dear BASCOM user,
> system components.
Hi Mark!
The log file:
Does it matter which LIC file I use (as I received two of them )?
Bye,
Christoph |
Posted: Sun Oct 03, 2004 10:30 pm Post subject: |
It seems WININET.DLL (explorer file) is causing the problem. The tool uses this windows system file. Probably in combination with some unknown factors it creates these problems.
I am rewriting the tool now so it does not uses wininet.dll anymore. _________________ Mark |
Posted: Mon Oct 04, 2004 12:08 am Post subject: |
I rewrite the Wizzard so wininet is not used/needed anymore.
You can download the update which has been tested in W98.
One problem remains : Error 216 is reported by some users.
On XP SP2. _________________ Mark |
earlwb
Posted: Mon Oct 04, 2004 3:15 am Post subject: The current 1.0.0.2 version, it is working for me |
The newer 1.0.0.2 version worked Ok for me on my PC running Windows XP Pro SP2, with Symantec internet Security Firewall, Norton Anti-Virus, and a Broadband router. I did have to tell the firewall to permit the program to access the internet though. I also told the anti-virus software to skip the scanning of the downloads.
I did have a problem with version 1.0.0.0 (humm maybe it was 1.0.0.1) in that it got stuck in a endless loop upgrading itself to the version 1.0.0.2 UpdateWizard. But I broke out of it and ran the newer version directly.
Earl |
Frankeman
Posted: Mon Oct 04, 2004 11:31 am Post subject: |
Quote: | One problem remains : Error 216 is reported by some users.
On XP SP2.
With Version 1.0.0.2 this is stil true. |
Posted: Wed Oct 06, 2004 9:02 pm Post subject: |
Problem found and fixed in version 1.0.0.3 that is uploaded.
There is also a setup button on the first screen now that allows you to enter proxy info and the time out of the connection(in seconds).
The pdf was also updated. _________________ Mark |
