Loader firmware via serial port
Post new topic   Reply to topic    www.mcselec.com Forum Index -> AVR
bibibo
PostPosted: Fri Apr 12, 2013 1:32 pm    Post subject: Loader firmware via serial port Reply with quote
Hi, I develop Visual Basic application for setting my device and i would like to add to my VB application loader firmware. I don not know how it works. Is anywhere a guide ?
(BASCOM-AVR version : 2.0.7.6 )
amirf
PostPosted: Tue Apr 30, 2013 3:52 am    Post subject: Reply with quote
you may use avr mcs bootloader , search avr forum ...
Madf
PostPosted: Wed May 01, 2013 8:28 am    Post subject: Reply with quote
In fact lacks a simple engine to create your booting.
Examples are all based on the "mcs bootloader", to make their own, have a lot to clean/remove from the code is not correct, but because loader should be optimized, then it makes no sense to write in BASIC. According to this lack of finished operator/function for writing flash program memory.
ps: do not want to write everything in assembler. Confused
PostPosted: Wed May 01, 2013 9:06 am    Post subject: Reply with quote
maybe it will help you actually have a look at the samples. there are already asm samples which do not use the mcs bootloader. and these samples are just a sample to give you an idea what you can do. you need to adapt the samples for your own goal.
if it is not correct to remark or change some code you can better find a new hobby/job.
Post new topic   Reply to topic    www.mcselec.com Forum Index -> AVR All times are GMT + 1 Hour
