ATmega32m1
Goto page Previous  1, 2, 3
Post new topic   Reply to topic    www.mcselec.com Forum Index -> AVR
PeterM
PostPosted: Wed Apr 10, 2013 2:10 pm    Post subject: Reply with quote
They have connectors as well, pretty much everything.
http://www.obd2cables.com/products/obd-connectors/
Peter
PostPosted: Wed Apr 10, 2013 8:32 pm    Post subject: Reply with quote
thanks!
Paulvk
PostPosted: Wed Apr 10, 2013 11:54 pm    Post subject: Reply with quote
I hope this means you are working on an OBD2 library, ODB has huge interest only have to look at the blog section to see the large number of views, of course it would only come with the full version I think it would raise your sales of bascom considerably.
Regards Paul
mlcarter
PostPosted: Thu Apr 11, 2013 12:38 am    Post subject: Reply with quote
Hello Mark
I could not source a plug but purchased a cable as above.
Then a SN65HVD230-32 TRANSCEIVER from DigiKey.
I have not progressed far, the compiler does not like the CANIT interrupt for the at32M1. I shall poll the registers to get it going for a start.
PostPosted: Thu Apr 11, 2013 9:33 am    Post subject: Reply with quote
i ordered 2 plugs. one from china and one from the US. now i need to wait.
for the canint you need to use : CAN_INT
I changed it because canint was a constant used by atmel.
it is visible in the dat file (look at the [INTLIST] section.
PostPosted: Thu Apr 11, 2013 9:40 am    Post subject: Reply with quote
Tapping into my cars CAN was an old idea/wish. When Elektor asked me to write an article i spend some time diving into it. I then wrote the CAN lib based on the atmel chips with CAN interface.
Since Elektor made a good board for it, i decided to use the CAN32 chip. So the sample is for that board/chip. But it should work for other chips as well.
There is no special lib required for talking to the car CAN bus. But you need info about the id's to send and what to expect. Some info differs from car to car Sad
the code i showed before is all you need : a MOB for sending and a MOB for receiving. if i get my connector i will make a sample.
or maybe someone beats me to it Smile
Post new topic   Reply to topic    www.mcselec.com Forum Index -> AVR All times are GMT + 1 Hour
Page 3 of 3
