7 inch display board
Goto page Previous  1, 2
Post new topic   Reply to topic    www.mcselec.com Forum Index -> BASCOM Project Blog
bzijlstra
Bascom Ambassador
PostPosted: Sun Mar 17, 2013 8:11 am    Post subject: WordClock with temperature and humidity Reply with quote
We put a DHT11 sensor on location JP1 and from www.AVRprojects.ru we have download software to read the DHT11.
Now we got the time and date from the DS1338-33 and temperature and humidity from a DHT11.
Time to make a WordClock. Fontsize 25x32. So on a 800 x 480 pixel display we can make 13 lines of 31 characters.
It is a running clock, the text is refreshed three times a minute so it is very dynamic.
In real the blue is less intensive.
Code follows.
Have fun
Ben Zijlstra
Theo Kleijn
Paulvk
PostPosted: Sun Mar 17, 2013 9:44 am    Post subject: Reply with quote
Nice project Ben Very Happy
Have you checked the accuracy of the DHT11 , I can not get valid readings when I compare them to my wet/dry bulb hygrometer which is an actual meteorological instrument ?
Regards Paul
bzijlstra
Bascom Ambassador
PostPosted: Sun Mar 17, 2013 8:55 pm    Post subject: iTrax300 GPS module Reply with quote
The next step is the iTrax300 GPS module. It is the WIZFI210 or the Itrax300 GPS module, they are on the same serial lines.
Same trick to connect a PC direct to the iTrax300 module.
Here the output of the module.
Have fun
Ben Zijlstra
Theo Kleijn
bzijlstra
Bascom Ambassador
PostPosted: Sun Mar 17, 2013 9:12 pm    Post subject: TSR 1-2450 instead of 7805 Reply with quote
Using a switch mode regulator
There is a switched mode regulator available which is pin compatible with the 7805 regulator and a similar size. The 7805 regulator is supposed to be roughly 55% efficient where as the switch mode regulator TSR 1-2450 is supposed to be roughly 95% efficient.
Due to the backlight of the display, the 7805 got warm/hot, with the TSR 1-2450 no problem.
Have fun
Ben Zijlstra
Theo Kleijn
PostPosted: Mon Mar 18, 2013 10:36 am    Post subject: Reply with quote
I love that clock.
And thanks for the info about the traco power chip and GPRS module.
You say they share the same line, but when connecting to the PC right? According to the circuit they seem to have their own connection to the processor module.
bzijlstra
Bascom Ambassador
PostPosted: Fri Mar 29, 2013 6:48 am    Post subject: Source WordClock with temperature and humidity Reply with quote
Here the source of our Easter Word Clock.
Have fun
Ben Zijlstra
Theo Kleijn
Easter project 2013
PostPosted: Sat Mar 30, 2013 12:38 pm    Post subject: Reply with quote
hi Ben & Theo,
thanks for the source, that is indeed a nice project for this Easter Smile
Wish you Happy Easter !
Post new topic   Reply to topic    www.mcselec.com Forum Index -> BASCOM Project Blog All times are GMT + 1 Hour
Page 2 of 2
