danilomayojr
Joined: 17 Feb 2010 Posts: 36 Location: San Fernando City
Posted: Wed Jan 16, 2013 8:42 am Post subject: COLOR SENSOR - TCS3471 IC |
Hi 8051 gurus,
I am a hobbyist and working on my new project which is color sensing device. I got the color sensor module from our shop - TCS3471. I'll include here the schematic and datasheet of the IC. Here's the site were you can download the said module
http://www.e-gizmo.com/KIT/COLOR%20SENSOR.html
This is my first time to deal with I2C that is why im asking for help how to get data from this module if you can add sample code in a very simple way will be super much appreciated.
I just want to read two colors yellow and green
I hope you can help me here people.. Thank you so much! _________________ Danilo Mayo Jr. |
kimmi
Posted: Fri Jan 18, 2013 5:17 pm Post subject: |
I never used the 8051 only Bascom-avr
so I did download demo version for test
seems like it can compile it ok
you have to setup the mcu xtal and pins for SDA SCL I dont know howto in 8051
something like this but check in help there is more info about I2C:
Code: |
' config I2C bus
Config Scl = P3.6
' I2C Clock
Config Sda = P3.7
' I2C Data |
but think you can use some of the info in the code
the code init TCS3471
then it can read the RGBC
the read is low high byte of the color and it make a word from the 2 bytes
I did use address H14 to read all (start with Clear) but you can use address pr datasheet for the R G B C
see datasheet for RGBC Channel Data Registers (0x14 − 0x1B)
this I hope will work for the TCS3471
Code: | ' datasheet
'http://www.ams.com/eng/content/download/250256/975981/142695
Const Tcs3471w = &H52
Const Tcs3471r = &H53
Declare Sub Rgb_init()
Declare Sub Rgbc_read()
Dim Light As Word
Dim Clear_l As Byte
Dim Clear_h As Byte
Dim Red As Word
Dim Red_l As Byte
Dim Red_h As Byte
Dim Green As Word
Dim Green_l As Byte
Dim Green_h As Byte
Dim Blue As Word
Dim Blue_l As Byte
Dim Blue_h As Byte
Dim A As Byte
Call Rgb_init
Call Rgbc_read
'add you'r code here
' Tcs3471 Vars value
'Light (clear)
'Red
'Green
'Blue
'Datasheet
'Table 1. Register Address
'Table 2. Command Register
'Table 3. Command Register
'init TCS3471
Sub Rgb_init()
I2cstart
I2cwbyte Tcs3471w
I2cwbyte &B10100000
I2cstop
Waitms 10
I2cstart
I2cwbyte Tcs3471w
I2cwbyte 0
I2cwbyte &B00001001
I2cstop
Waitms 10
I2cstart
I2cwbyte Tcs3471w
I2cwbyte 0
I2cwbyte &B00001011
I2cstop
Waitms 10
End Sub
'Datasheet Table 12. ADC Channel Data Registers
Sub Rgbc_read()
I2cstart
I2cwbyte Tcs3471w
I2cwbyte &H14
I2cstart
I2cwbyte Tcs3471r
I2crbyte Clear_l , Ack 'Clear low
I2crbyte Clear_h , Ack 'Clear high
I2crbyte Red_l , Ack 'red high
I2crbyte Red_h , Ack 'red low
I2crbyte Green_l , Ack 'green high
I2crbyte Green_h , Ack 'green low
I2crbyte Blue_l , Ack 'blue high
I2crbyte Blue_h , Nack 'blue low
I2cstop
Light = Makeint(clear_l , Clear_h) ' make word from low - high
Red = Makeint(red_l , Red_h)
Green = Makeint(green_l , Green_h)
Blue = Makeint(blue_l , Blue_h)
End Sub |
_________________ / Kim |
danilomayojr
Posted: Sat Jan 19, 2013 3:19 am Post subject: |
Thanks kimni.. I will test the code later and i will post it here any details i will get. Again thank you so much for the support...  _________________ Danilo Mayo Jr. |
danilomayojr
Posted: Mon Feb 04, 2013 2:48 am Post subject: |
Good Day Sir,,
After several test.. i find nothing ;( i think my code is wrong... heres the whole code you send me plus i included my little code to display on LCD the values of RGB...
Please Help... Thank you so much
$large
$crystal = 11059200
Config Lcd = 16 * 2
Config Lcdpin = Pin , Db4 = P0.5 , Db5 = P0.4 , Db6 = P0.3 , Db7 = P0.2
Config Lcdpin = Pin , Rs = P0.0 , E = P0.1
'LCD INITIALIZATIONS
Lcdinit
Wait 2
Display On
' config I2C bus
Config Scl = P2.0
' I2C Clock
Config Sda = P2.1
' I2C Data
Dim Light As Word
Dim Clear_l As Byte
Dim Clear_h As Byte
Dim Red As Word
Dim Red_l As Byte
Dim Red_h As Byte
Dim Green As Word
Dim Green_l As Byte
Dim Green_h As Byte
Dim Blue As Word
Dim Blue_l As Byte
Dim Blue_h As Byte
Dim A As Byte
Call Rgb_init
Call Rgbc_read
Locate 1 , 1 : Lcd Red
Locate 1 , 7 : Lcd Blue
Locate 2 , 1 : Lcd Green
Wait 3
'Light (clear)
'Red
'Green
'Blue
'Datasheet
'init TCS3471
Sub Rgb_init()
I2cstart
I2cwbyte Tcs3471w
I2cwbyte &B10100000
I2cstop
Waitms 10
I2cstart
I2cwbyte Tcs3471w
I2cwbyte 0
I2cwbyte &B00001001
I2cstop
Waitms 10
I2cstart
I2cwbyte Tcs3471w
I2cwbyte 0
I2cwbyte &B00001011
I2cstop
Waitms 10
End Sub
Sub Rgbc_read()
I2cstart
I2cwbyte Tcs3471w
I2cwbyte &H14
I2cstart
I2cwbyte Tcs3471r
I2cstop
End Sub _________________ Danilo Mayo Jr. |
kimmi
Posted: Mon Feb 04, 2013 6:51 am Post subject: |
Hi
dont know chip model
they use 2 address
try
Const Tcs3471w = &H72
Const Tcs3471r = &H73 _________________ / Kim |
danilomayojr
Posted: Tue Feb 05, 2013 12:50 am Post subject: |
i also tried it but nothing happen in the datasheet i found address, attached in this thread to help you sir).
i also found an interrupt pin.. whats the use of this sir?? _________________ Danilo Mayo Jr. |
kimmi
Posted: Tue Feb 05, 2013 3:14 am Post subject: |
we can add read Chip ID for a test
then you know if I2C is working
and of cause you run 8051 at 3.3V max
Code: |
$large
$crystal = 11059200
Config Lcd = 16 * 2
Lcdinit
Wait 2
Display On
' config I2C bus
Config Scl = P2.0
' I2C Clock
Config Sda = P2.1
' I2C Data
Config I2cdelay = 20
Declare Sub Id()
Dim Id_chip As Byte
' check chip ID 0x14 = TCS34711 & TCS34715 0x1D = TCS34713 & TCS34717
Call Id
Locate 1 , 1
Lcd Id_chip
Locate 2 , 1
If Id_chip = &H14 Then
Lcd "TCS34711/15"
Elseif Id_chip = &H1D Then
Lcd "TCS34713/17"
Else
Lcd "ERROR READ"
Wait 2
Cls
Sub Id()
I2cstart
I2cwbyte Tcs3471w
I2cwbyte &H12
I2cstart
I2cwbyte Tcs3471r
I2crbyte Id_chip , 9
End Sub |
danilomayojr
Posted: Tue Feb 05, 2013 4:22 am Post subject: |
THIS IS THE DISPLAY SIR:
18
ERROR READ
tHANKS FOR THE HELP _________________ Danilo Mayo Jr. |
kimmi
Posted: Tue Feb 05, 2013 5:11 pm Post subject: |
try change Config I2cdelay = 1
chip can handle 400khz _________________ / Kim |
danilomayojr
Posted: Fri Feb 08, 2013 3:03 am Post subject: |
Sir,
After changing Config I2cdelay = 1
display is this
79
error read
-------------------------- _________________ Danilo Mayo Jr. |
