Do you like SUSI project? |
What are you working on??? |
6% |
[ 1 ] |
Hard to understand, not enough information available! |
13% |
[ 2 ] |
Didn't own Hardware, but using parts of Software from SUSI |
13% |
[ 2 ] |
Using the SUSI Project |
53% |
[ 8 ] |
Made own Driver for SUSI Project |
13% |
[ 2 ] |
Total Votes : 15 |
six1
Posted: Fri Feb 01, 2013 8:43 am Post subject: |
Hi mmarlette,
the W5100 driver is gone
Will see, that i implement it. The W5100 has only 4 Sock.
The SUSI Project was, for my understanding, for hughe CPU's so i decided to make W5200 and W5300 work.
best, michael _________________ For technical reasons, the signature is on the back of this message. |
mmarlette
Posted: Fri Feb 01, 2013 5:37 pm Post subject: |
six1 wrote: | Hi mmarlette,
the W5100 driver is gone |
I see that!
best, michael |
So noted but......From post #1 of this thread the project reference is X_ALVIDI_six1.bas project file.
Which from the user setup const area, Const Ethernet = 1, which is the W5100.
The target uC is $regfile = "XM128A1DEF.DAT" , which is a larger uC.
So per your example we are not able to build the project with SUSI 5.0 to the W5100 without modifications?
If that is the case then, based upon SUSI, if the ethernet const was changed to 2 and the target hardware was swapped to the W5200. All that would have to be done is recompile X_ALVIDI_six1.bas and it would function 100% if the rules of SUSI were followed?
Regards,
Mark |
six1
Posted: Fri Feb 01, 2013 9:04 pm Post subject: |
..the clou is, that you can compile the sources for different micros!
If worked on the w5100 sources and also implemented Drivers for TC77 and DS1820 (B,S) Temp sensors.
This is in the Download on page 1 (SUSI 5 rev 1)
BUT the W5100 are not tested, because i hadn't have the time today nor the hardware! If you have hardware for testing it, please report bugs!
best, Michael _________________ For technical reasons, the signature is on the back of this message. |
