Flash area writing
P_Santos
PostPosted: Fri Jan 04, 2013 5:42 pm    Post subject: Flash area writing Reply with quote
Hello,
I need write many times during program execution one byte at a non-volatile memory location
One possibility would be in the eeprom of the Atmega. According to the Datasheet, each
cpu eeprom cell supports as much as 100,000 written, what for my case would be a long-term impediment
In addition to the time of approx. 15ms it is necessary to complete the writing.
Is there any way to write the byte i need in the micro Flash area so that don't have this
limitation of quantities and timing of written?
Apreciate any help
Thanks
Best regards
P_Santos
PostPosted: Fri Jan 04, 2013 8:26 pm    Post subject: Reply with quote
answer : no.
possible alternatives :
- back up battery
- external fram (ramtron) chip
- more intelligent write where you use an array and count the number of writes.
P_Santos
PostPosted: Sat Jan 05, 2013 3:45 pm    Post subject: Reply with quote
Thank You Albertsm
Luciano
PostPosted: Sat Jan 05, 2013 4:04 pm    Post subject: Reply with quote
I read from one of your previous post that you are using the DS1307.
Just use the non-volatile SRAM of your RTC chip.
The DS1307 serial real-time clock (RTC) is a lowpower,
full binary-coded decimal (BCD) clock/calendar
plus 56 bytes of NV SRAM.
56-Byte, Battery-Backed, General-Purpose RAM with Unlimited Writes.
Datasheet: LINK
Best regards,
Luciano
Evert :-)
PostPosted: Sat Jan 05, 2013 4:08 pm    Post subject: Reply with quote
You can use something like "High endurance eeprom storage" http://www.atmel.com/Images/doc2526.pdf
I will look Monday at my work if i can find the code in Bascom.
Tiny
PostPosted: Sat Jan 05, 2013 4:51 pm    Post subject: Reply with quote
I had the same problem, i must store a power-on timer to log the time that de unit is powered.
i do al logging every minute, 100000 minutes = 1666 hrs
i need-it al least 30000 hrs totale
the solution for me is that is use an index counter that points to the eprom location that where used for the logtimer
eprom locations
'  199 = index tbv row teller logtimer
'  200...203  204...207  208...211  212...215  216...219
'  220...223  224...227  228...231  232...235  236...239
'  240...243  244...247  248...251  252...255  256...259
'  260...263  264...267  268...271  272...275  276...279
Dim Logtimer As Dword                                       'hold runtime
Dim Byte_1 As Byte At Logtimer Overlay
Dim Byte_2 As Byte At Logtimer + 1 Overlay
Dim Byte_3 As Byte At Logtimer + 2 Overlay
Dim Byte_4 As Byte At Logtimer + 3 Overlay
Sub Updatelogtimer()
   Local Teller As Integer
   Teller = 4
   Teller = Teller * Indexlogtimer
   Teller = Teller + 200
   Readeeprom E2prom_waarde , Teller
   Byte_4 = E2prom_waarde
   Incr Teller
   Byte_3 = E2prom_waarde
   Incr Teller
   Byte_2 = E2prom_waarde
   Incr Teller
   Byte_1 = E2prom_waarde
   Incr Logtimer
   If Logtimer > 100000 Then
      Logtimer = 1
      Incr Indexlogtimer
      If Indexlogtimer = 20 Then Indexlogtimer = 0
      Writeeeprom Indexlogtimer , 199
   Teller = 4
   Writeeeprom Byte_4 , Teller
   Incr Teller
   Writeeeprom Byte_3 , Teller
   Incr Teller
   Writeeeprom Byte_2 , Teller
   Incr Teller
   Writeeeprom Byte_1 , Teller
   Print , "Uptime: " ; Logtimer ; " minuts"
End Sub
Tiny
Evert :-)
PostPosted: Sat Jan 05, 2013 5:12 pm    Post subject: Reply with quote
@Tiny
But what happens after an power failure? you don't know the value of logtimer anymore and therefore you can't know what the last used eeprom address was.
P_Santos
PostPosted: Sat Jan 05, 2013 7:35 pm    Post subject: Reply with quote
Hello Luciano,
Great idea, thank you
Sometimes during program execution i need to save a byte value, in this case on register 9 NV SRAM of the DS1307
On powerup i need to get this value from the DS1307
Can this code work?
dim bin_pos as byte
Get_pos:                   'on Powerup get the value of register 9
  I2cstart                                                  ' init start
  I2cwbyte Ds1307w                                          ' send adress
  I2cwbyte 9                                                ' choose the register
  I2cwbyte Ds1307r                                          ' send adress
  I2crbyte Bin_pos , Nack                                   ' get the value of register 9 on the DS1307 and save it on var bin_pos
  I2cstop
Set_pos:   'sometimes during program execution save the value of var bin_pos to the register 9 of DS1307
  I2cwbyte Ds1307w                                          ' send address
  I2cwbyte Bin_pos                                          ' and write the value of bin_pos to the register 9 NV SRAM of 1307
  I2cstop
Best regards
P_Santos
Luciano
PostPosted: Sat Jan 05, 2013 8:26 pm    Post subject: Reply with quote
Use two bytes of SRAM in the DS1307 RTC chip, in the first byte you store a flag,
in the second byte you store your value.
(Pseudocode)
When you write:
- Write 170 in the first byte (flag). (DEC 170 = BIN 10101010).
- Write the value in the second byte.
- Read back the value from the second byte.
- If the read value is OK, write 85 in the first byte (flag). (DEC 85 = BIN 1010101).
When you read:
Read the flag value from the first byte.
If flag = 85 then
Read the value from the second byte
Else
Restore default value or print error
Endif
When read 85 from the first byte, then you know that the value in the
second byte was written OK.
I don't know what you are storing, but if you use more bytes,
you can store the current value and the previous one and use
this second one in case the current value is corrupted.
(In case the value of the flag is not 85).
Best regards,
Luciano
Tiny
PostPosted: Sat Jan 05, 2013 9:24 pm    Post subject: Reply with quote
Evert Smile wrote:
@Tiny
Sorry not al the code is show,
location 199 off the eprom holds the indexlogtimer, on powerup i read that vale and then i read the last saved logtimer value calculated as show in code below
Sub Read_logtimer()
   Teller = 4
   Incr Teller
   Incr Teller
   Incr Teller
End Sub
