Avr drives PNP transistor
Post new topic   Reply to topic    www.mcselec.com Forum Index -> AVR
amirf
PostPosted: Fri Aug 10, 2012 11:08 am    Post subject: Avr drives PNP transistor Reply with quote
Hallo All ,
yes avr pin can drive npn transistor (like tip41) via 120 ohm resistor , but i am no luck driving pnp transistor (like TIP42C) using avr pin , any ideas how to drives PNP transistor using avr pin ?
six1
PostPosted: Fri Aug 10, 2012 1:01 pm    Post subject: Reply with quote
PNP -> R between Emitter and Basis (4K7) this is for getting high impedance between Collector Emitter
additional NPN Transistor. Emitter to Ground, Base with 1K to Port Pin and Collector with 2K2 to Basis PNP
those values are only for testing 5-12V ... you have to optimize them!
If you need more Power, you can google for "mosfet high side switch".
best, Michael
For technical reasons, the signature is on the back of this message.
amirf
PostPosted: Sat Aug 11, 2012 2:49 am    Post subject: Reply with quote
Thanks Michael for Great Info
Best Regards
Post new topic   Reply to topic    www.mcselec.com Forum Index -> AVR All times are GMT + 1 Hour
