Posted: Tue Aug 07, 2012 7:28 pm Post subject: Problems with the timing
Ok the issue with the switches is solved.
I have a another issue with the timing of the wait and waitms if I write the value with the wait 1 (wait 1 second) it will take about 5 seconds to pass.
I have the program posted here and I am a little bit curious about the reactions.
$regfile = "m32def.dat"
$crystal = 16000000
' port configuration
Config Portd = Output ' Setting port D for output
Config Portb = Input ' Setting port B for input
Portb.0 = 1 ' Activate pull up
Portb.1 = 1
'statements
Dim Teller As Byte
Dim Functie As Byte
Dim Strt As Byte
Dim Timerspeed As Byte
Strt = 0
Timerspeed = 10
If Pinb.0 = 0 Then Incr Strt
If Pinb.1 = 0 Then Timerspeed = 250 Else Timerspeed = 10
Portd = &B10000000
Waitms 5
Portd = &B00000000
Loop Until Strt = 1
Strt = 0
Incr Teller
Portd = Teller
Waitms Timerspeed
If Teller = &HFF Then Functie = 1
Loop Until Functie = 1
Teller = &HFF
Functie = 0
Portd = Teller
Decr Teller
Waitms Timerspeed
If Teller = 0 Then Functie = 1
the simulator can not simulate in real time. this means that depending on the used pc, 1 waitms 1000 will take a fraction of a second, or multiple seconds.
the pc need to perform other tasks as well so the sim can not get 100% of the resources. a waitms 1000 will executes thousands of instructions (a loop with a number of instructions).
To remove delays of wait, waitms, you can read about $sim in the help. _________________ Mark
Ok, I have burn this code to my proc and the timing is of the wait 250 instruction generates about 1 second in real time.
I am glad to have any info about this to correct this little problem.
you specify this : $crystal = 16000000
but is that the actual clock speed?
you can use : config clockdiv=1 , to make sure there is no divisor active. But you should also check the fuse bytes. Maybe you run on the internal oscillator? _________________ Mark
