Luciano
Posted: Wed Dec 08, 2010 9:23 pm Post subject: |
Your program must keep track of the cursor position.
As I said, in my library are only low-level routines
which are called by the Bascom compiler.
Luciano |
glena
Joined: 25 Jul 2007 Posts: 284 Location: PA near Philly
Posted: Fri Sep 09, 2011 3:10 pm Post subject: |
Luciano,
Thanks for putting in the time out so that if there is a hardware error with the LCD the program will continue and not lock up.
Once very small addition I would consider is setting a failed flag if the time out is reached. This will (if desired) give the programmer the option of knowing that there is a hardware issue and maybe taking some other action. I consider this a very low priority and would not add it unless there are other changes being made.
-Glen _________________ http://bahbots.com |
Ross_ValuSoft
Joined: 20 Nov 2005 Posts: 275 Location: Melbourne, Australia
Posted: Sun Sep 11, 2011 6:22 am Post subject: |
Adding my thanks also Luciano.
Cheers,
Ross McKenzie
Melbourne Australia |
Frankeman
Posted: Mon May 07, 2012 3:10 pm Post subject: |
Hi Luciano,
Are you willing to enhance the LUC_Lcd4busy_timeout library so that the internal ERR flag is set when a timeout occurs.
Just like for example the HexVal and I2Csend statements does.
Best regards, Frank |
Frankeman
Posted: Wed May 09, 2012 6:23 pm Post subject: |
In the "Mixing ASM and BASIC" topic in the help file is described how to set the ERR flag.
ASM is not my favorite thing, but i think it can be done in a few lines of ASM. |
Luciano
Posted: Sun May 13, 2012 2:28 pm Post subject: |
Hi Frank,
Not really useful because the LCD can also crash while its busy flag is low.
You can also have an LCD where the communication works OK but with
no output on the LCD because the display driver is broken.
(If you still want to implement it).
Recent AVR chips have General Purpose I/O Registers.
(ATmega48/88/168datasheet).
The ATmega48/88/168 contains three General Purpose I/O Registers.
These registers can be used for storing any information, and they
are particularly useful for storing global variables and Status Flags.
General Purpose I/O Registers within the address range 0x00 - 0x1F are
directly bit-accessible using the SBI, CBI, SBIS, and SBIC instructions.
With these three registers (GPIOR0, GPIOR1 and GPIOR2) you have space for
up to 24 flags.
Below is what you have to do to set and clear one of these flags in my LIB.
(First we set our flag GPIOR0,0 and then we clear it if no timeout occurred).
In your Bascom program, in order to detect the error you will have to
check if the bit is set in the register GPIOR0.
(If GPIOR0.0 = 1 Then...).
You can do the same with the Bascom ERR flag (R6 bit 2) but then you are
not sure if the error was raised by the LCD routine or by a function you have
called as parameter in the Bascom LCD command. (In case this function
also uses ERR). Same problem if the Bascom ERR flag is set by the code in
an interrupt service routine which has interrupted the LCD command.
Luciano
(File LUC_lcd4busy_timeout.lib).
Code: | ....
_LCD_Busy:
* sbi gpior0,0 ; !!!!!!! Set your LCD error flag !!!!!!!!
* cbi _LcdE_PORTx, _LcdE_PinNumber ; Clear the pin E
* cbi _LcdRW_PORTx, _LcdRW_PinNumber ; Clear the pin RW
* cbi _LcdRS_PORTx, _LcdRS_PinNumber ; Clear the pin RS
* sbi _LcdE_DDRx, _LcdE_PinNumber ; Set E as output
* sbi _LcdRW_DDRx, _LcdRW_PinNumber ; Set RW pin as output
* sbi _LcdRS_DDRx, _LcdRS_PinNumber ; Set RS pin as output
rcall _Clear_Nibble ; Clear DB4,DB5,DB6 and DB7
* cbi _LcdDB4_DDRx, _LcdDB4_PinNumber ; Set DB4 as input
* cbi _LcdDB5_DDRx, _LcdDB5_PinNumber ; Set DB5 as input
* cbi _LcdDB6_DDRx, _LcdDB6_PinNumber ; Set DB6 as input
* cbi _LcdDB7_DDRx, _LcdDB7_PinNumber ; Set DB7 as input
* sbi _LcdRW_PORTx, _LcdRW_PinNumber ; Setup to read busy flag
* sbi _LcdE_PORTx, _LcdE_PinNumber ; Set E pin
@genus(2) ; Wait for 2uS
* in R25, _LcdDB7_PINx ; Read busy flag from LCD into R25
* cbi _LcdE_PORTx, _LcdE_PinNumber ; Clear E pin
rcall _Toggle_E_line ; Toggle E line to get rid of lower nibble
dec R16 ; Decrement timeout value in R16
breq _bf_timeout ; Branch when timeout expires. (R16=0)
* sbrc R25, _LcdDB7_PinNumber ; Check busy flag stored in R25, high = busy
rjmp _LCD_Busy ; Busy flag was high so we check it again
* cbi gpior0,0 ; !!!!!!! Clear your LCD error flag !!!!!!!!
_bf_timeout: ; Jump here when a timeout occurs
* cbi _LcdRW_PORTx, _LcdRW_PinNumber ; Back to write mode
Frankeman
Posted: Mon May 14, 2012 9:39 pm Post subject: |
Hi Luciano,
Thank you very much for your explanation.
It takes only two lines of ASM.
I really like to know when a LCD fails.
The hardware monitors the carbon monoxide value in fluegasses.
Nobody looks at the display until a level is measured that is to high.
In that case it would be nice if the display works (-:
When the display craches under normal conditions it can be replaced.
Frank. |
TSEYFARTH
Posted: Mon Aug 17, 2015 3:16 am Post subject: |
Hi Luciano,
I am trying to use your LUC_lcd4busy_timeout.lib but cannot get it to compile without changing LCDMODE to from PIN to BUS. The compiler errors are:
Error40 Line 2346 Variable can not be used with RESET [PORTG], in file
Error41 Line 2346 Variable can not be used with SET [PORTG], in file
I am using an ATMEG32a
$regfile = "m32def.dat" 'register file for MEGA32A-AU
$crystal = 16000000 '16MHz crystal
$baud = 9600
$hwstack = 175 '200 '100 ' default use 32 for the hardware stack
$swstack = 180 '200 '100 ' default use 10 for the SW stack
$framesize = 112 '100 '40 ' default use 40 for the frame space
$lib "LUC_lcd4busy_timeout.lib"
'*** These 4 pins are not used by Lucianos code ****
Config Portc.0 = INPUT 'Output
Config Portc.1 = INPUT 'Output
Config Portc.2 = INPUT 'Output
Config Portc.3 = INPUT 'Output
'PCB2.39 012014 for Leamington
' LCD AVR
' pin pin
'//--- REQUIRED PINS ---//
'DB4 'PC.4
'DB5 'PC.5
'DB6 'PC.6
'DB7 'PC.7
'ENABLE 'PB.0
'R/W 'PB.1 'Note that RW must be connected to a pin!
'RS 'PB.2
'//--- NOT USED LCD PINS ---//
'DB0 'PC.0
'DB1 'PC.1
'DB2 'PC.2
'DB3 'PC.3
Const _LcdDB4_PORTx = PortC 'Valid values: PORTA, PORTB, PORTC, PORTD, PORTE.
Const _LcdDB4_DDRx = DDRC 'Valid values: DDRA, DDRB, DDRC, DDRD, DDRE.
Const _LcdDB4_PinNumber = 4 'Valid values: 0, 1, 2, 3, 4, 5, 6, 7.
Const _LcdDB5_PORTx = PortC 'Valid values: PORTA, PORTB, PORTC, PORTD, PORTE.
Const _LcdDB5_DDRx = DDRC 'Valid values: DDRA, DDRB, DDRC, DDRD, DDRE.
Const _LcdDB5_PinNumber = 5 'Valid values: 0, 1, 2, 3, 4, 5, 6, 7.
Const _LcdDB6_PORTx = Portc 'Valid values: PORTA, PORTB, PORTC, PORTD, PORTE.
Const _LcdDB6_DDRx = DDRc 'Valid values: DDRA, DDRB, DDRC, DDRD, DDRE.
Const _LcdDB6_PinNumber = 6 'Valid values: 0, 1, 2, 3, 4, 5, 6, 7.
Const _LcdDB7_PORTx = Portc 'Valid values: PORTA, PORTB, PORTC, PORTD, PORTE.
Const _LcdDB7_DDRx = DDRc 'Valid values: DDRA, DDRB, DDRC, DDRD, DDRE.
Const _LcdDB7_PINx = Pinc 'Valid values: PINA, PINB, PINC, PIND, PINE.
Const _LcdDB7_PinNumber = 7 'Valid values: 0, 1, 2, 3, 4, 5, 6, 7.
Const _LcdE_PORTx = PortB 'Valid values: PORTA, PORTB, PORTC, PORTD, PORTE.
Const _LcdE_DDRx = DDRB 'Valid values: DDRA, DDRB, DDRC, DDRD, DDRE.
Const _LcdE_PinNumber = 0 'Valid values: 0, 1, 2, 3, 4, 5, 6, 7.
Const _LcdRW_PORTx = PortB 'Valid values: PORTA, PORTB, PORTC, PORTD, PORTE.
Const _LcdRW_DDRx = DDRB 'Valid values: DDRA, DDRB, DDRC, DDRD, DDRE.
Const _LcdRW_PinNumber = 1 'Valid values: 0, 1, 2, 3, 4, 5, 6, 7.
Const _LcdRS_PORTx = PortB 'Valid values: PORTA, PORTB, PORTC, PORTD, PORTE.
Const _LcdRS_DDRx = DDRB 'Valid values: DDRA, DDRB, DDRC, DDRD, DDRE.
Const _LcdRS_PinNumber = 2 'Valid values: 0, 1, 2, 3, 4, 5, 6, 7.
'Define the used LCD
'Start off as 20x2 but set later depending on the jumper setting
' If Lcd2or4 = 1 Then
Config Lcd = 20 * 2
' Else
' Config Lcd = 20 * 4
' End If
Initlcd
Cursor Off Noblink
If I set it to BUS, then it kinds of works. It starts out as a 20x2, but then changes to a 16x2 - there is no code from me to do this. I have tested the same board with the same display (A Newhaven OLED Character display) and it does work - aside from loosing a character on left, by having what appears to be column 1 moved to the left over time. Newhaven told me it was a timing error in code, which is why I am trying your lib. Previously I had used this code:
Config Portc.1 = Output
Config Portc.2 = Output
Config Portc.3 = Output
Config Portb.0 = Output 'LCD Enable
Config Portb.1 = Output 'LCD R/W
Config Portb.2 = Output 'LCD Reg Sel
Config Lcdpin = Pin , Db4 = Portc.4 , Db5 = Portc.5 , Db6 = Portc.6 , Db7 = Portc.7 , E = Portb.0 , Rs = Portb.2
Lcd2or4 = Pinb.6
If Lcd2or4 = 1 Then
Config Lcd = 20 * 2 , Chipset = Ks077 '4 'configure lcd screen
Config Lcd = 20 * 4 , Chipset = Ks077 '4 'configure lcd screen
Initlcd 'Initialize the LCD
Portb.1 = 0 'Set the W/R Pin to logic zero(0)
Cursor Off Noblink
Curiously, if I modify the above to include the RW pin, I get similar errors.
Further, Newhaven says their display uses a ST7066U chipset.
I have found datasheets that suggest the following are compatible, including the one you wrote about in your lib
HD44780
KS0063
KS0065B
Any ideas and help would be really appreciated!
Thank you,
Tim |
