Posted: Tue Nov 15, 2005 1:19 pm Post subject: some questions-no problems
I just started using the prototype board. Some troubles, which are solved now, brought up some questions:
- the avrpins.exe shows in the mega128 in brackets adress-lines, ad-lines aso. I assume, these are the connections used by the library- Is ths correct?
- I tried it with the mega8515. It works fine with a 4MHz crystal, it does not work with a 16MHz crystal. Where are the limits? And why?
- I want to use ad-converters in my system together with some calculation. Since maximum clock-speed seems to be aproblem-how about the cpu-load by the ip-programming?
The maximum clock speed depends on the used chip.
So test first if a normal program will work.
At very high clcck speed it might be needed to use a different clock mode.
Refer to the W3100 manual for the Mode0 and Mode1 pins that select the clock mode. _________________ Mark
