saqmaster
Joined: 10 Apr 2004 Posts: 42 Location: United Kingdom
Posted: Wed Sep 15, 2004 8:07 am Post subject: RS232, hard or soft? |
I have a requirement to parse a serial datastream.. Its constructed of a start byte, four data bytes, and a checksum byte..
So.. i've seen the ischarwaiting() function.. Would it be suitable just to have a loop which checks if there is a char, and then act on it? Or do you have to use a software uart to get the buffer? Can anyone clarify how it works?
I've seen how you can configure a buffer with config serialin, but then you have to use OPEN etc.. If you just do a basic $baud and ischarwaiting() and inkey(), how big is the buffer? (if there is one)..
Thanks
Stu |
oe9vfj
Joined: 17 Jun 2004 Posts: 269 Location: Austria, Hard
Posted: Wed Sep 15, 2004 8:28 am Post subject: |
As far as I know, Soft-UART has no buffer. You must call the INKEY() before the char receives.
I advise you to use the Hardware-UART of the chip and config a small Serialin-buffer. This gives you more flexibility.
Than you can check in a loop with ischarwaiting(), whether there are character(s) in the buffer and read it out with INKEY().
The size of the buffer depends of your loop time and the baud-rate of your rs232 connection. _________________ regards Josef
DOS - File System for BASCOM-AVR on http://members.aon.at/voegel |
saqmaster
Posted: Wed Sep 15, 2004 9:48 am Post subject: |
Cool. thanks.
As the data is coming through as 5 single bytes in a packet, should I use inkey() or inputbin, do you think?
-Stu |
oe9vfj
Posted: Wed Sep 15, 2004 10:38 am Post subject: |
I would use INKEY, but don't know exactly the difference between INKEY and INPUTBIN according to your problem.
I think, to read to a BYTE is is the same. With INPUTBIN you can read to other variables than BYTE too.
But you have to check for the starting byte, so you have to check each received byte and storing them to an array or whatever you want. _________________ regards Josef
DToolan
Joined: 14 Aug 2004 Posts: 1384 Location: Dallas / Fort Worth, Texas (USA)
Posted: Wed Sep 15, 2004 4:35 pm Post subject: |
Personally, I would make a buffer and receive the characters and perform the checksum calculation in the background via ISR.
This routine isn't all inclusive but gives you another idea of how it could be done.
Code: | $REGFILE = "m128def.dat" '<- whatever your chip is
$CRYSTAL = 16000000 '<- your crystal
$BAUD = 9600 '<- USART0 baud rate
DIM USART0_Buffer(6) As Byte '<- 6 character buffer
DIM USART0_Pointer As Byte
DIM TEMP As Byte
DIM USART0_Status As Byte
DataReady ALIAS USART0_Status.1
StartCondition ALIAS USART0_Status.0
USART0_Pointer = 1 '<- initialize the pointer to the start of the buffer
StartByte ALIAS USART0_Buffer(1)
DataByte1 ALIAS USART0_Buffer(2)
DataByte2 ALIAS USART0_Buffer(3)
DataByte3 ALIAS USART0_Buffer(4)
DataByte4 ALIAS USART0_Buffer(5)
ChkSumByte ALIAS USART0_Buffer(6)
CONST TRUE = 1
CONST FALSE = 0
CONST PASSED = 0
CONST StartByteValue = &H03 '<- make this whatever your start byte is supposed to be
DIM ChecksumCode As Byte
CONFIG Com1 = Dummy , Synchrone = 1 , Parity = None , Stopbits = 1 , Databits = 8 , Clockpol = 0
ENABLE URXC : ON URXC USART0_RXC_ISR 'allow interrupts on USART0 receive complete
ENABLE INTERRUPTS 'globally allow interrupts to occur
'MAIN
DO
WHILE DataReady = TRUE
'do something with DataByte1
'do something with DataByte2
'do something with DataByte3
'do something with DataByte4
'you are done so reset the DataReady flag
DataReady = FALSE
WEND
LOOP
END
USART0_RXC_ISR:
TEMP = UDR '<- put the contents received from the UART data register into TEMP
IF TEMP = StartByteValue THEN '<- see if it matches your start byte value
StartCondition = TRUE
END IF
IF StartCondition = TRUE THEN
SELECT CASE USART0_Pointer
CASE 1 'the start byte
USART0_Buffer(USART0_Pointer) = TEMP
INCR USART0_Pointer '<- increment for the next character to come
CASE 2 TO 5 '4 data bytes
INCR USART0_Pointer '<- increment for the next characters to come
CASE 6 'the checksum byte
'here you can perform a test of the buffer and checksum
'i don't know your checksum code so we'll just pretend it's here
'and it's result is called ChecksumCode
'checksum routines should equal zero when perfomed on an array
'that includes a checksum received
IF ChecksumCode = PASSED THEN 'the result of the checksum routine is zero
DataReady = TRUE 'let the main program know it can do whatever it wants with this data
StartCondition = FALSE 'reset for the next data packet to arrive
USART0_Pointer = 1 'reset the buffer pointer for the next data packet
ELSE 'checksum test routine says the data failed
END IF
END SELECT
END IF
RETURN |
saqmaster
Posted: Wed Sep 15, 2004 4:48 pm Post subject: |
Excellent, thankyou. I like the way you've laid it out.. Thanks for your time.. |
