I installed Bascom version 2.0.7.3 on Windows 7 and it stays
pgiatis
PostPosted: Sun Dec 25, 2011 9:19 pm    Post subject: I installed Bascom version 2.0.7.3 on Windows 7 and it stays Reply with quote
Hi I transferred my copy of Bascom AVR version 2.0.7.3 on a new Windows 7 laptop. Once I installed it I rebooted the computer per the installation instructions and transferred my BASC-AVR.DLL to the directory folder and it starts up and then hangs on the splash screen and never loads the programs.....any help would be appreciated.
W4GNS
PostPosted: Mon Dec 26, 2011 12:04 am    Post subject: Reply with quote
I recently had the same problem,I solved it by redownloading the "Full" program again.
Bascom-AVR 2.0.7.6
Programmer USBASP (China Version)
pgiatis
PostPosted: Mon Dec 26, 2011 7:07 am    Post subject: Tried that Reply with quote
Yes, I tried uninstalling and re-installing a fresh copy and still no go..
KenHorse
PostPosted: Tue Dec 27, 2011 10:58 pm    Post subject: Re: Tried that Reply with quote
If by "reinstalling" you mean you simply copied the entire directory structure on your other computer to your new one, you can't do that. You need to run the actual installation program to properly register runtime libraries, etc on your new machine. After you've done that, THEN you can copy over your "old" directories.
PostPosted: Wed Dec 28, 2011 11:12 pm    Post subject: Reply with quote
if you follow the instructions from the Help, it should work just fine.
"BASC-AVR.DLL"
That is NOT the license dll. If you tried to rename/use this as a license dll it will not work for sure.
I advise to follow the instructions from the CD/email you got when you purchased.
