glena
Joined: 25 Jul 2007 Posts: 284 Location: PA near Philly
Posted: Sun Mar 28, 2010 4:41 am Post subject: Playstation2 controller code |
I'm currently working on a RoboMagellan project and was using a VEX 6 channel radio for RC control but started needing more buttons so I decided to look into trying a wireless Playstation2 controller I got from Eddy Wright a while back. Eddy had an example of working with the PS2 controller but the code used the hardware SPI. I needed the hardware SPI for File IO with a MicroSD card so I decided to rewrite it to not require or interfere with the other SPI commands or hardware. The result turned out to work very well and makes using a PS2 controller much more appealing for shot distance control.
I hope others are able to use the code in there projects!
The actual code is very small, less then 20 lines total!
Here is full example:
Code: | '===============================================================================
' Project: PlayStationII Wireless (or wired) controller reader
' Version: v1.0
' Created: 2010-03-27
' By: Glen Aidukas (C)Bahbots.com
' Credits: Original help from Eddy Wright on the PS2 protocol
' Description:
' PS2 Shockwave controller wiring and PSI data reading
' _____________________________
' | |1 2 3||4 5 6||7 8 9| | <-- Male connector of controller
' \___________________________/
' Pin Color Function Notes
' 1 GREEN MISO Data In
' 2 WHITE MOSI Command out
' 3 VIBRATE +9V
' 4 BLACK GND
' 5 RED VCC 3.3V-5V
' 6 BLUE SS Select
' 7 YELLOW SCK Clock
' 8 N/C N/C
' 9 ACK N/C
' This code was tested and working with a wireless PlayStationII controller
$regfile = "m644pdef.dat"
$crystal = 18432000
$hwstack = 32
$swstack = 16
$framesize = 48
$baud = 38400
'=====[ Dimension and initialize variables ]====================================
Dim PS2_CMD(2) as Byte ' init cmd sent to PS2 controller
Dim PS2_Data(7) as Byte ' hold returned data from PS2 controller
Dim i as Byte ' General purpose variables
PS2_MISO alias pinc.7 : DDRC.7= 0 ' data in
PS2_MOSI alias portc.6 : DDRC.6= 1 ' data out
PS2_SS alias portc.5 : DDRC.5= 1 ' Select
PS2_SCK alias Portc.4 : DDRC.4= 1 ' Clock
PS2_MISO= 1 ' turn on internal pull up resister
PS2_CMD(1) = &H01 ' Start Command
PS2_CMD(2) = &H42 ' Request Data
print "{027}[2J"; ' ansi clear screen...
print "Starting..."
gosub PS2_Read ' read the PS controller data
print "{027}[3;1H"; ' move to page top (ansi)
Print "Byte1 : "; PS2_Data(1); " "
print
Print "Select: "; PS2_Data(2).0 ; " Start : "; PS2_Data(2).3
Print "ThumbL: "; PS2_Data(2).1 ; " ThumbR: "; PS2_Data(2).2
print
Print "CNT-Up: "; PS2_Data(2).4 ; " CNT-R : "; PS2_Data(2).5
Print "CNT-Dn: "; PS2_Data(2).6 ; " CNT-L : "; PS2_Data(2).7
print
Print "L1 : "; PS2_Data(3).2 ; " R1 : "; PS2_Data(3).3
Print "L2 : "; PS2_Data(3).0 ; " R2 : "; PS2_Data(3).1
print
Print "Triang: "; PS2_Data(3).4 ; " Cross : "; PS2_Data(3).6
Print "Circle: "; PS2_Data(3).5 ; " Square: "; PS2_Data(3).7
print
print "Joy RX: "; PS2_Data(4); " "
print "Joy RY: "; PS2_Data(5); " "
print "Joy LX: "; PS2_Data(6); " "
print "Joy LY: "; PS2_Data(7); " "
waitms 100
'=====[ Read the PS2 controller data ]==========================================
PS2_Read:
PS2_SS = 0 ' assert select line
SHIFTOUT PS2_MOSI, PS2_SCK, PS2_cmd(1) , 2, 8, 20 ' send start command
SHIFTOUT PS2_MOSI, PS2_SCK, PS2_cmd(2) , 2, 8, 20 ' send request data cmd
For i = 1 To 7
SHIFTIN PS2_MISO, PS2_SCK, PS2_Data(i), 2, 8, 20 ' read in data
Next i
PS2_SS = 1 ' release select line
return
_________________ http://bahbots.com
Posted: Sun Mar 28, 2010 12:22 pm Post subject: Nanchuck |
Have seen also Nanchuck code for the Arduino, but written in C. Is also wireless... Have tested it, working well.
have fun
Ben Zijlstra |
eddy
Joined: 09 Apr 2004 Posts: 67 Location: Near Chicago, IL USA
Posted: Thu Sep 22, 2011 9:38 pm Post subject: |
Hello All,
I tested Glen's code last night and it works great. I have also used SPI hardware mode with success but I tried SPI software last night and I can't get it to work. Has anyone tried SPI in software mode to connect a PS2 controller? I think the issue could be timing since the clock is derived in software instead of the system clock.
I don't really need SPI software mode but for sake of completeness, I would like to get it working too.
I'll post the code tonight though the only difference between SPI hardware and software is the config statement.
Thanks,
Eddy Wright _________________ Eddy Wright
Wright Hobbies, LLC
http://www.wrighthobbies.net |
