how can i make 89s52 i2c sniffer ?
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    www.mcselec.com Forum Index -> BASCOM-8051 Archive
solar1
PostPosted: Mon Nov 21, 2005 7:24 am    Post subject: how can i make 89s52 i2c sniffer ? Reply with quote
how can i make 89s52 as i2c sniffer , i have som panel that sends data via i2c i want to listen this transmision i dont want steal messages .. i write some program in bascom but it steal messages ;/ i know what i want to hear and from what adress HELP ?
Dim A As Bit
Dim C As Bit
Dim D As Bit
Dim E As Bit
Config Sda = P0.1
Config Scl = P0.0
Dim Value1 As Byte
Dim Value2 As Byte
I2creceive 32 , Value1
If Value1 = 1 Then
If Value1 = 2 Then
 If Value1 = 4 Then
 If Value1 = 8 Then
program do something
  I2creceive 36 , Value 2
  If Value2 = 1 Then
  If Value2 = 2 Then
   If Value2 = 128 Then
Bascom Ambassador
PostPosted: Mon Nov 21, 2005 9:34 am    Post subject: I2c-tracer Reply with quote
Could you have a look at
http://members.home.nl/bzijlstra/hardware/I2Ctrace/I2Ctrace.htm
Bye
Ben Zijlstra
solar1
PostPosted: Mon Nov 21, 2005 7:30 pm    Post subject: Reply with quote
pc is't 89S52 !! i need do this on 89s52
This forum is locked: you cannot post, reply to, or edit topics.   This topic is locked: you cannot edit posts or make replies.    www.mcselec.com Forum Index -> BASCOM-8051 Archive All times are GMT + 1 Hour
