BASCOMB
Posted: Fri Jul 01, 2011 3:58 pm Post subject: List SUBDir |
Niclas,
Thanks for the great tool!
It works just fine.
how can I get a list of the Subdirectories of the root?
For example like “DIRLIST_Scroll or DEMO_Scroll”.
Would you have a small programm (demo) or any other idea ?
best regards, Ernst |
KokkeKat
Posted: Fri Jul 01, 2011 8:19 pm Post subject: |
Hi Ernst
Thanks for your appreciation!
The dirlist routine is meant to be called from a loop, limited by Sddirliststartpoint=1, Sddirlistendpoint=1, or Sdstatus=32.
When you want to get a list of subdirectories (to any directory), do something like this:
' In the declaration section, define the size of the array that stores the current directory's clusters. You can set it to as low as 1, but you will get much faster directory scrolling if you don't have to follow the cluster chain for each previous cluster when going backwards. Below is just a "any" value.:
Const Sddirlistarraysize = 12
' The actual code:
Sdstartdirclusterd = 0 ' Set it to 0 as a dummy value for root directory - if FAT32, you can also set it to 2
Sdclusterd = Sdstartdirclusterd
Sddirlistarraycounter = 0
Sddirlistdirection = 0
Sdstatus = 0
Gosub Sddirlist
If Sdstatus = 27 then
' Here you copy the content you need from array Sddirlistdirentry() (and the whereabouts) to your array that contains the subdirectory names.
' Or, just PRINT the name of each entry. (Especially when dealing with long file names, you probably won't want to store each 256-byte long LFN in an array...)
Loop Until Sddirliststartpoint=1 Or Sddirlistendpoint=1 or Sdstatus=32
' From the Sddirlist code:
' Routine-specific Sdstatuses:
' 26 = A file entry has been found
' 27 = A directory entry has been found
' 28 = An available directory space has been found
' 32 = EOD End Of Directory marker found
' 33 = Subdirectory . or .. entry found
' 34 = A volume ID has been found
' 36 = Long file name found
' Since the first directory entry can't have both status and start of directory status, this bit indicates that we have returned to the starting point
' Sddirliststartpoint = 1 ' The directory backward listing has reached the starting point
' Sddirlistendpoint = 1 ' The directory forward listing has reached the end point
' Sddirlistoutside = 1 ' We have scrolled outside of Sddirlistarray() array
Kind regards
Niclas |
BASCOMB
Posted: Sat Jul 02, 2011 12:23 pm Post subject: |
hi Niclas,
thanks for the reply. The list of root I can therefore spend as you suggest
have you an example of how I'm spending the list of directories?
SD-Card:
SUBDIR1
SUBDIR2
| +--File21
| +--File22
SUBDIR 3
File1
File2
the below example works correctly and gives out the root:
SUBDIR1
SUBDIR2
SUBDIR 3
File1
File2
but how do I get a list of SUBDIR2: ??
File21
File22
please give me an example
best regards, Ernst
Sdstatus = 0
Gosub Sdinit
If Sdstatus = 0 Then Gosub Sdinitfs
Sdstatus = 0
Gosub Sddirlist
if Sdstatus = 26 Or Sdstatus = 27 Then ' File oder Verzeichnis gefunden
Aset = ""
For Sdtempw2 = 1 To 12
Aset = Aset + Chr(sddirlistdirentry(Sdtempw2))
Next Sdtempw2
print #2 , "-->" ; Aset
Loop Until Sdstatus = 32
KokkeKat
Posted: Sat Jul 02, 2011 5:17 pm Post subject: |
Hi Ernst
You need to find the cluster number, in which SUBDIR2 starts. Inside the loop that your describe, do something like this:
Dim Esddirfound As Bit
Sdstatus = 0
Gosub Sdinit
Gosub Sdinitfs
Esddirfound = 0
Sdstatus = 0
Gosub Sddirlist
' [If file/subdirectory name = "SUBDIR2" Then]
Sdclusterb(1) = Sddirlistdirentry(27)
Sdclusterb(2) = Sddirlistdirentry(28 )
Sdclusterb(3) = Sddirlistdirentry(21)
Sdclusterb(4) = Sddirlistdirentry(22)
Esddirfound = 1
' End If
Loop Until Sddirliststartpoint=1 Or Sddirlistendpoint=1 or Sdstatus=32 Or Esddirfound = 1
If Esddirfound = 1 Then
Sdstartdirclusterd = Sdclusterd
' Here you do the loop you described
Please notice that you must end the loop at least with this:
Only looking for Sdstatus = 32 will miss the case when the last directory entry is the very last entry in the cluster. (In which case it's the FAT that tells you that the current cluster is the last in the chain.)
Kind regards
Niclas |
njepsen
Posted: Sat Jul 02, 2011 11:19 pm Post subject: |
Niclas,
what doe the d on the end of the label sdstartclusterd mean?
neil _________________ Neil |
BASCOMB
Posted: Sun Jul 03, 2011 9:00 am Post subject: |
Hi Niclas,
That was exactly the solution!.
Many thanks for your help.
KokkeKat
Posted: Sun Jul 03, 2011 1:29 pm Post subject: |
Hi Neil
The trailing letter (when it exists) means:
d = DWORD
l = LONG
w = WORD
b = BYTE
I use them especially when I overlay two variables. (See the declarations file for examples.)
Kind regards
I am happy to hear that I could help you Ernst.
Kind regards
Niclas |
