Change in PRINT in 2.0.6.0?
KenHorse
PostPosted: Sat May 28, 2011 11:56 pm    Post subject: Change in PRINT in 2.0.6.0? Reply with quote
The following worked fine in 2.0.5.0 and earlier:
$regfile = "m128def.dat"
$hwstack = 800                                              '100
$swstack = 500                                              '200
$framesize = 300                                            '600
$Baud = 9600
Dim TestString As String * 10
 Print "VM " + TestString + ",0" + Chr(13) ;
Under 2.0.6.0, it reports this error when compiling
Error : 42 Line : 12 Numeric parameter expected ["VM] , in File : C:\MCS Electronics\BASCOM-AVR\testprint.bas
Error : 31 Line : 12 Invalid datatype [[0011] 0[13)]] , in File : C:\MCS Electronics\BASCOM-AVR\testprint.bas
I assume it's the CHr(13) ?
( I see nothing in the history file nor the new HELP file that would explain this change)
hgrueneis
PostPosted: Sun May 29, 2011 7:08 am    Post subject: Reply with quote
There is nothing in the Help file that would suggest the use of a plus sign (at least I can not find any).
If you replace it with a semicolon then it works.
It also works if you use a separate print command for CHR(X).
Hubert
mattcro
PostPosted: Sun May 29, 2011 3:31 pm    Post subject: Reply with quote
This change in behaviour may be due to a bug fix related to strings:
History.txt for 2.0.6.0
- using {034} and quotes gave a problem when they were unbalanced.
The correct way to print multiple variables is to use the semicolon. The contatenation (plus sign) seems to give odd results sometimes.
BascomAVR 2.0.8.5
PostPosted: Tue May 31, 2011 10:48 pm    Post subject: Reply with quote
indeed the correct way is to use semicolon, but i changed it so + will work as well. this will keep code compatible.
