single data type sending through serial port
omid_juve
PostPosted: Sat May 28, 2011 6:57 am    Post subject: single data type sending through serial port Reply with quote
i have 4 single data type . i want to send it through serial port .
how can i do this ? (i mean with what instruction should i use to send and receive it ?)
six1
PostPosted: Sat May 28, 2011 8:15 am    Post subject: Reply with quote
there are several way's...
easiest is to send it as string.
Have a look at FUSING in Bascom Helpfile...
For technical reasons, the signature is on the back of this message.
omid_juve
PostPosted: Sat May 28, 2011 11:21 am    Post subject: Reply with quote
how can i get this string in another micro?(if i use fusing)
what instruction should i use?
PaulC
PostPosted: Sat May 28, 2011 12:38 pm    Post subject: Reply with quote
maybe you could store them in eeprom and send bytes across to other micro and then restore the bytes sent to ready made variables i.e. 2 for word lower and upper ending in 00 and 1 for byte ending in 00, and so on..
Bascom Avr 2.0.7.3
Works for me
Visovian
PostPosted: Sat May 28, 2011 4:26 pm    Post subject: Reply with quote
On the receive side use
Dim Str1 As String * 10
Dim Var1 As Single
Input Str1
Var1 = Val(str1)
The transmitted value is in Var1.
mattcro
PostPosted: Sat May 28, 2011 4:54 pm    Post subject: Reply with quote
You could also try PRINTBIN and INPUTBIN. I haven't tried this but guess it should work.
If all else fails, read the manual. Even better: read the manual before something fails. If you can't find it in the manual, search the forum.
BascomAVR 2.0.8.2
hgrueneis
PostPosted: Sat May 28, 2011 6:12 pm    Post subject: Reply with quote
mattcro is right, use PRINTBIN and INPUTBIN. It works.
Just DIM the receiving variables the same type as the transmitting variables.
I usually use a leading marker-character (that is not used otherwise) for a start and variable marking and wait for that, so the receiver knows which variable to store the data to. Useful for changing sequences of transmission.
The transmissions have to be the type of variables you use at the receiver, otherwise you collect garbage because it waits for the exact number of bytes that are contained in a certain variable type. See HELP file.
Hubert
amirf
PostPosted: Mon May 30, 2011 5:30 am    Post subject: Reply with quote
splite into byte , both variable in receiving and transmitting side , IMHO
omid_juve
PostPosted: Tue May 31, 2011 8:30 pm    Post subject: Reply with quote
i am connecting two micro using txd rxd pin . i use below program for communicating between these two micro . but when i run it in proteus
just i have this at the screen of the lcd " -nan" . could you plz help me what my problem is ?
transmitter side
Serialcheck Alias Pinb.0
Dim W6 As Single
W6 = -123.4
If Serialcheck = 0 Then
Waitus 100
Printbin w6
Waitms 30
receiver side:
dim w14 as single
If Adcupdate = 0 Then 'the "adcupdate" is a pushbutton key'
Reset Serialcheck
Inputbin W14
Lcd W14
Set Serialcheck
Wait 1
omid_juve
PostPosted: Wed Jun 01, 2011 3:03 pm    Post subject: Reply with quote
please help me
kimmi
Moderator
PostPosted: Wed Jun 01, 2011 3:38 pm    Post subject: Reply with quote
Hi
I tested this setup and that works ok (even in Proteus)
' TX
$regfile = "m16def.dat"
$crystal = 8000000
$hwstack = 32
$swstack = 20
$framesize = 40
$baud = 9600
Dim W6 As Single
W6 = -123.4
   Waitms 400
   Incr W6                                                     ' just as test for diffrent value on RX LCD show
   Printbin W6
' RX
$crystal = 8000000
$hwstack = 32
$swstack = 20
$framesize = 40
$baud = 9600
Config Lcdpin = Pin , Rs = Portb.2 , E = Portb.3 , Db4 = Portb.4 , Db5 = Portb.5 , Db6 = Portb.6 , Db7 = Portb.7
Config Lcd = 16 * 2
Cursor Off Noblink
Cls
Dim W6 As Single
   Inputbin W6
   Cls
   Lcd Fusing(w6 , "00.000")
/ Kim
View user's profile Visit poster's website MSN Messenger
