Posted: Sat May 28, 2011 11:14 am Post subject: kiXAHRS_ONE update 1.1
KiXAHRS_ONE Update 1.1
Bugs removed:
(1) Registers ASAX, Y, Z were not displayed correctly during read registers AK8975.
Add ons:
(1) New main menu entry: Ignore magnetic overflow/Don't ignore magnetic overflow. Some AK8975 magnetometers give self test results which are just outside the window of acceptable parameters on one or more magnetometer axes. This may happen if measurements are taken inside buildings or in magnetically disturbed environments. Menu option 4 now determines how to proceed in such situations. If the menu shows Don't ignore magnetic overflow and you press 4, magnetic overflow will not be ignored afterwards. This holds for:
(a) compass calibration
(b) magnetometer readouts
(c) yaw gyro drift correction, viz. only correct data will be considered in the DCM.
The setting is stored in the EEPROM if you press CR in the main menu.
(2) Reading AK8975 registers is now combined with performing the self test.
NK
thanks for your support.
I changed your quota, let me know when you reach it again, there is one other setting i could change but i do not know the effect. _________________ Mark
