Bascom 2.0.5.0 LCD error?
Robert7x
PostPosted: Fri Apr 29, 2011 6:00 pm    Post subject: Bascom 2.0.5.0 LCD error? Reply with quote
The code cannot work:
Config Lcd = 16 * 2
Initlcd
Cls
Lcd "1.        2.  "
Complie, and the result is:
via Bascom 2.0.5.0: 1.2.
via Bascom 2.0.3.0: 1. 2.
If I change 1. to 1; -> everything is OK. The problem is a dot.
Any advice?
http://wwwr.tavir.hu - AVR hungarian site (Arduino & Bascom tutorials and examples)
athomeelectronics
PostPosted: Sat Apr 30, 2011 2:57 pm    Post subject: Reply with quote
Doh! I've seen similar problems with 2.0.5.0!
If I print "This. And that." to serial port, the space after dot disappears. I thought it was just my eyes, but the case is, space is not printed at all.
This is indeed a bug. I haven't had a time to find out is this a bug in print/lcd statement, or is Bascom losing data inside constant when a code is compiled.
PostPosted: Sat Apr 30, 2011 10:15 pm    Post subject: Reply with quote
this is indeed a bug which i introduced when i rewrote some code.
i will make a fix for this asap.
the problem is with all constant strings that use a dot. they are wrong stored/converted.
Munktell
PostPosted: Wed May 11, 2011 11:48 am    Post subject: Reply with quote
This bug is very serious for us as we are going to send a customer 40 mcu's today or tomorrow. When do you thing an updated bascom will be released or quick fix in library?
PostPosted: Wed May 11, 2011 11:51 am    Post subject: Reply with quote
if you have an SLA you can write to support to get a fix, otherwise you need to wait till the end of the week(end).
Munktell
PostPosted: Wed May 11, 2011 1:30 pm    Post subject: Reply with quote
We didn't have the support, but bought it and 5 min later the fix was in the SLA archive. Extreamly good support, thank you!
ivangel
PostPosted: Wed May 25, 2011 12:12 pm    Post subject: Reply with quote
whether this bug has been resolved? If so, where to download the update?
manekinen
PostPosted: Wed May 25, 2011 8:11 pm    Post subject: Reply with quote
I started to getting strange bugs if i used the "." char. Wasted some time and not found any bugs in code, so, this is a 2.0.5.0 problem...
At least, good to know! I have to read the forum most often Smile
Please fix this Smile
µProg – tiny, fast, portable AVR programmer with SD - bascom powered Wink
jene
PostPosted: Thu May 26, 2011 5:29 am    Post subject: Reply with quote
when will the fix be available ?
Thanks and BR
reinhars
PostPosted: Fri May 27, 2011 5:27 am    Post subject: Reply with quote
If space doesn't matter that could be used:
Sub Lcdtext(byval S As String , Xoffset As Byte , Yoffset As Byte , Fontset As Byte , Inverse As Byte , Rotation As Byte , Fontsize As Byte)
Local Tempstring As String * 1 , Temp As Byte               'Dim local the variables
Local H As Byte , Pixels As Byte , Count As Byte , Carcount As Byte , Lus As Byte
Local Row As Byte , Byteseach As Byte , Blocksize As Byte , Dummy As Byte
Local Colums As Byte , Columcount As Byte , Rowcount As Byte , Stringsize As Byte
Local Xpos As Byte , Ypos As Byte , Pixel As Byte , Pixelcount As Byte
If Inverse > 1 Then Inverse = 0                             'Inverse can't be greater then 1
If Rotation > 3 Then Rotation = 0                           'There are only 4 rotation's
Stringsize = Len(s) - 1                                     'Size of the text string -1 because we must start with 0
For Carcount = 0 To Stringsize                              'Loop for the numbers of caracters that must be displayed
 If Fontset = 1 Then Restore Font8x8                        'Add or remove here fontset's that you need or not,
 If Fontset = 2 Then Restore Font8x12                       'this is the name that you gave to the font, NOT the filename
' If Fontset = 3 Then Restore Font6x8                        'If you dont know the name, open the font file in wordpad, and there it is,
' If Fontset = 4 Then Restore Font5x5                        'right on top.
 Temp = Carcount + 1                                        'Cut the text string in seperate caracters
Tempstring = Mid(s , Temp , 1)
Read Row : Read Byteseach : Read Blocksize : Read Dummy     'Read the first 4 bytes from the font file
Temp = Asc(tempstring) - 32                                 'Font files start with caracter 32
For Lus = 1 To Temp                                         'Do dummie read to point to the correct line in the fontfile
   For Count = 1 To Blocksize
    Read Pixels
   Next Count
Next Lus
Colums = Blocksize / Row                                    'Calculate the numbers of colums
Row = Row * 8                                               'Row is always 8 pixels high = 1 byte, so working with row in steps of 8.
Row = Row - 1                                               'Want to start with row=0 instead of 1
Colums = Colums - 1                                         'Same for the colums
Select Case Rotation
    Case 0                                                  '0 degrees rotation
            For Rowcount = 0 To Row Step 8                  'Loop for numbers of rows
                  H = Rowcount + Yoffset
                  For Columcount = 0 To Colums              'Loop for numbers of Colums
                      Read Pixels : If Inverse = 1 Then Toggle Pixels       'Read the byte from the file and if inverse = true then invert de byte
                      Xpos = Columcount                     'Do some calculation to get the caracter on the correct Xposition
                      Temp = Carcount * Byteseach
                      Xpos = Xpos + Temp
                      Xpos = Xpos + Xoffset
                          For Pixelcount = 0 To 7           'Loop for 8 pixels to be set or not
                             Ypos = H + Pixelcount          'Each pixel on his own spot
                             Pixel = Pixels.0               'Set the pixel (or not)
                             Pset Xpos , Ypos , Pixel       'Finaly we can set the pixel
                             Shift Pixels , Right           'Shift the byte 1 bit to the right so the next pixel comes availible
                             Bytearray(1) = Rowcount + Pixelcount
                             Incr Bytearray(1)
                             If Bytearray(1) > Fontsize Then Exit For
                          Next Pixel
                  Next Columcount
            Next Rowcount
    Case 1                                                  '90 degrees rotation
            For Rowcount = Row To 0 Step -8                 'Loop is now counting down
                  H = Rowcount + Xoffset
                  H = H - 15                                'Correction to set Xpos on Xoffset with rotation
                      Xpos = Columcount
                      Xpos = Xpos + Temp
                      Xpos = Xpos + Yoffset                 'We want that Xoffset is still Xoffset, so we need here the change from x to y
                             For Pixelcount = 7 To 0 Step -1
                                Pixel = Pixels.0
                                Pset Ypos , Xpos , Pixel
                             Next Pixel
                  Next Columcount
            Next Rowcount
    Case 2                                                  '180 degrees rotation
                  H = H - 7                                 'Correction to set Xpos on Xoffset with rotation
                  For Columcount = Colums To 0 Step -1
                      Xpos = Columcount
                      Xpos = Xpos - Temp
                      Xpos = Xpos - 8                       'Correction to set Xpos on Xoffset with rotation
                             Pixel = Pixels.0
                          Next Pixel
                  Next Columcount
            Next Rowcount
    Case 3                                                  '270 degrees rotation
                      Xpos = Columcount
                      Xpos = Xpos - Temp
                                Pixel = Pixels.0
                             Next Pixel
                  Next Columcount
            Next Rowcount
End Select
Next Carcount
End Sub                                                     'End of this amazing subroutine
$include "font/Font8x8.font"                                'Includes here your font files
$include "font/Font8x12.font"                               'If you don't need the files in your program, don't include them,
'$include "font/Font6x8.font"                                'these are flash memory eaters.
'$include "font/Font5x5.font"
Edit: After posting this i saw that you use char-lcd - the code is for graphic lcd...
