Problems with {034} inside strings in Print statements
mattcro
PostPosted: Mon May 16, 2011 5:06 pm    Post subject: Problems with {034} inside strings in Print statements Reply with quote
I'm trying to use the {034} trick in string constants to insert quotation marks in AT commands, but the strings are not correctly compiled. For example:
Dim Gprs_apn As String * 30
Gprs_apn = "my.ip.com"
Print "AT+CGDCONT=1,{034}IP{034},{034}" ; Gprs_apn ; "{034},{034}0.0.0.0{034},0,0" ; Chr(&H0d)
In the simulator and real program execution I get the following output:
AT+CGDCONT=1,"IP","" ; Gprs_apn ; "","0.0.0.0",0,0
Of course, I hoped to get the actual APN as part of the output string, but Bascom seems get confused with the {034} and the string delimiter quote marks... can this be considered as a bug? This is in version 2.0.5.0.
As a workaround I am using Quote() or Chr(34).
If all else fails, read the manual. Even better: read the manual before something fails. If you can't find it in the manual, search the forum.
BascomAVR 2.0.8.2
MAK3
PostPosted: Mon May 16, 2011 5:39 pm    Post subject: Reply with quote
Hi mattcro,
to get this:
AT+CCLK="10/02/15,08:02:00"
I use:
Print #2 , "at+cclk=" + Chr(34) + Sm5100_year + "/" + Sm5100_month + "/" + Sm5100_day + "," + Time$ + Chr(34)
(all variables are strings)
MAK3
bzijlstra
Bascom Ambassador
PostPosted: Mon May 16, 2011 8:30 pm    Post subject: Quote... Reply with quote
This is also a nice solution...
Dim A1 As String * 20
Dim A2 As String * 20
Dim A3 As String * 50
A1 = "AT+CCLK="
A2 = Quote( "10/02/15,08:02:00")
A3 = A1 + A2
Print A3
You can test it in the simulator...
Have fun
Ben Zijlstra
PostPosted: Mon May 16, 2011 8:38 pm    Post subject: Reply with quote
Print "AT+CGDCONT=1," ; Quote( "IP") ; "," ; Quote(Gprs_apn) ; "," ; Quote( "0.0.0.0") ; ",0,0" ; Chr(&H0d)
AT+CGDCONT=1,"IP","my.ip.com","0.0.0.0",0,0
Very Happy
mattcro
PostPosted: Mon May 16, 2011 8:59 pm    Post subject: Reply with quote
It looks like the parser/compiler gets confused, and treats some of the {034} as delimiter quote marks instead of part of the literal string. Some more tests:
print "this is {034}quoted{034} text and works OK"
print "this is correctly {034}quoted{034} text " ; "with concatenation"
print "this is just one correctly printed quote mark: {034}"
print "This does not work {034} " + "more text"
print "but {034}this{034} example {034} works correctly"
print "with just one {034} quote" + " and concatenation it goes wrong"
print "with a {034}pair{034} of quotes" + " and concatenation it works OK"
print "with {034}pairs{034} of quotes" + " and {034}concatenation{034} it goes funny"
print "the content of gprs_apn is {034}" + gprs_apn + "{034}. Wrong concatenation and the space before Wrong is missing"
print "this causes multiple <label too long, parentheses missing, numeric parameter expected> compile errors {034}" + gprs_apn
BascomAVR 2.0.8.2
PostPosted: Mon May 16, 2011 9:46 pm    Post subject: Reply with quote
Just wondering why you get stuck to an undocumented trick, while there's a dedicated function especially for the right use ?
And, if you'd insist it must work, not everything has to Smile
Print "{000}I do not want to be printed"
Evert :-)
PostPosted: Mon May 16, 2011 9:56 pm    Post subject: Reply with quote
It's not an undocumented trick, it's described in the help file under Language Fundamentals.
s= "AB{027}cd"
It doesn't work at described, so it looks like a bug.
athomeelectronics
PostPosted: Tue May 17, 2011 8:11 am    Post subject: Reply with quote
Similar thread:
http://www.mcselec.com/index2.php?option=com_forum&Itemid=59&page=viewtopic&t=9334&highlight=
PostPosted: Tue May 17, 2011 2:15 pm    Post subject: Reply with quote
when you use print, you can best use ;
print "something" ; somevar ; "etc"
the problem with multiple quotes is that it is hard to know what is part of the strings and what isnt.
print "s"""; """ ' is ; part of the string or not?
As it worked, it checks if there are surrounding quotes.
The {034} solution is nice, but it was converted too early to " internal , leading to problems.
I rewrote it, and i checked with print, assigning, const, etc.
It seems to work fine now but from experience i know there is always some construction that makes it fail.
so i will make a beta available for customers that can only be downloaded with the wiz.
i will add a news item when it is available.
mattcro
PostPosted: Tue May 17, 2011 7:38 pm    Post subject: Reply with quote
Ok Mark. I was going to write a support email but it looks like you are already working on this. Smile
Yes, it looks like the {xxx} gets converted to the corresponding byte value too early in the compile process, and then it is impossible to tell what is string delimiter and what is part of the string.
I wanted to have {034} in the strings to reduce the code size and execution time. It makes sense to have as few string concatenation operation in code execution as possible, when they can be stored as complete string constants.
When I was testing the {034} issues I tried with Print "this; myvar; "that" as well as Print "this" + myvar + "that" but I did not notice any difference. I guess the semicolon is the correct way to do it in a print statement though, since they are separate variables/constants.
BascomAVR 2.0.8.2
PostPosted: Tue May 17, 2011 7:53 pm    Post subject: Reply with quote
maybe you can write a test sample that uses print, const , if and assign using {034} and send it to support. i had to make some tricky changes and do not like to break existing {} code.
