Programmer
nguyenduonghoang
PostPosted: Sat Jul 10, 2010 4:35 am    Post subject: Programmer Reply with quote
Hi everybody,
I often use AVR910 to programming on AvrProg, fuse bit on code vision and it too inconvenient, anyone can help me diy a programmer, such as USB-ISP programmer.., im using laptop so i cant use skt200/300 on parallel port.
Thanks alot.
Best Regard.
hgrueneis
PostPosted: Sat Jul 10, 2010 5:12 am    Post subject: Reply with quote
I use AvrStudio4 from Atmel and the AVRISPmkll programmer from Atmel. It has USB, cable comes with the programmer and the latest firmware updates with AVRStudio4. It also comes with a 6-pin ISP ribbon cable with plug. No extra power supply needed...only for target.
In the USA it cost approx. $39. AVRStudio4 can be downloaded from Atmel with registration at no cost to you.
You can check on Atmel's website and STudio4 for compatibility with different AVR's. I think it is ideal for laptops.
Have fun
Hubert
nguyenduonghoang
PostPosted: Sat Jul 10, 2010 6:34 am    Post subject: Reply with quote
Hi Hgrueneis,
Thanks for your answer, but i want to programming by bascom with programmers was supported by bascom, i think it is more convenient than other.
Any ideal ?!
Best Regards.
Hoang.
ATIU
PostPosted: Sat Jul 10, 2010 9:11 am    Post subject: Reply with quote
Google Wrobot USBtinyASP, there are two versions Standard and Pro, both works with the latest version of BASCOM-AVR, you need to install the drivers for the USBASP from http://www.fischl.de/usbasp/
hellmut.kohlsdorf
PostPosted: Sun Oct 31, 2010 10:14 pm    Post subject: USB-ISP Programmer Driver Installation Reply with quote
In the Gerätemanger of my new PC, Windows 7 Ultimate 64 bits with i7-960 CPU the USB-ISP Programmer is listed, but missing the driver.
I did download the USB-ISP driver from the mcselc site, but whentrying to have the sriver installed out of the "Gerätemanager" it says no driver found. Sorry for being so foolish on windows issues, but how do i get the driver installed?
Hellmut
PostPosted: Sun Oct 31, 2010 10:50 pm    Post subject: Reply with quote
-Go to device manager.
-Look up USB-ISP
- select properties
- select update driver
- point to the unzipped usb-isp package you downloaded
that should fix it.
hellmut.kohlsdorf
PostPosted: Sun Oct 31, 2010 10:59 pm    Post subject: Reply with quote
Finally my problem is resolved. Thanks
Hellmut
