How to use Getrc5 and monitor port buttons same time?
jakim
PostPosted: Mon Aug 30, 2004 7:51 pm    Post subject: How to use Getrc5 and monitor port buttons same time? Reply with quote
My piece of hardware is intended to be amplifier remote control and digital control system . The problem is how to see the button debounce and getrc5 on the same loop. How to make a jump to the getrc5 routine so that it happens only when data received by Ir receiver.
This doesnt work-
enable interrupts
enable int0
begining:
on int0 receiverc5 nosave
'main program'
receiverc5:
getrc5(address and command)
etc.
goto begining
end
PostPosted: Tue Aug 31, 2004 10:05 pm    Post subject: Reply with quote
When you enter an ISR in AVR, the global interrupts are disabled.
This means you need to re-enable them, or better , only the interrupt you want to keep tickining like the timer interrupt that getrc5 is using.
In practice :
receiverc5:
disable int0 ' we dont want to come here again now
enable interrupts ' allow all ints
getrc5 address ,command
enable int0
RETURN ' exit ISR
jakim
PostPosted: Sat Sep 04, 2004 5:21 pm    Post subject: Reply with quote
i tried different loops and still cant get it to work . INT0 works and the ir command is identified but when i want the code to monitor input pins it doesnt work . Can somebody make me simple example which shows on lcd when button is pressed and when rc5 command is decoded
Frankeman
PostPosted: Sun Sep 05, 2004 7:43 am    Post subject: Reply with quote
This is Bascom 8051 code, but with minor changes it will work under Bascom AVR too.
Dim New As Bit
Dim Command As Byte , Subaddress As Byte
Reset Tcon.0                                                  'triggered by rising edge
On Int0 Receiverc5
Enable Int0
  Debounce P1.0 , 0 , Pr , Sub
  If New = 1 Then                                          'received new code
     Disable Int0
     Print Command ; "  " ; Subaddress
     New = 0                                                  'reset new bit
     Enable Int0
Receiverc5:                                                   'interrupt routine
  Getrc5(Subaddress,command)
  New = 1                                                      'set flag
Pr:
  Print "P1.0 was/is low"
