ATiny15 problems ...
johanvdb
PostPosted: Tue Aug 17, 2004 11:13 am    Post subject: ATiny15 problems ... Reply with quote
I'm able to compile a simple piece of code (LED flasher) for the ATiny15 and I can program the MCU from out of BASCOM. However, the code does not run. I can also verify the code from out of the programmer, so that is fine. When I download the code to another MCU (8535) it works fine. I do however use the header as in the atiny15 sample provided with BASCOM (which I don't use when taretting the 8535 however).
Can it be that there is something wrong with the ATiny15? Maybe I need to define the internal clock speed using the OSCAL register (0xff for max speed). It is a 15LS, maybe I need to run on 3V instead of 5V?
I'm not sure ... anybody an idea on what the problem can be?
Thanks!
Johan
DJD XTREEM
PostPosted: Wed Aug 18, 2004 10:07 am    Post subject: Reply with quote
Please post the code you use..
Because the smaller AVR procs have some problems with some of the statements off bascom..
Bascom AVR 1.11.8.8 full version
STK500 Programmer
ISP Programmer
johanvdb
PostPosted: Thu Aug 19, 2004 9:58 am    Post subject: Reply with quote
Ok ... here's the code:
$tiny
$regfile = "at15def.dat"
$noramclear
config pinb.4 = output
main:
   toggle portb.4
   wait 1
   goto main
For the moment I reverted back to the 2343 ... but I would rather want to benefit from the new parts like the 15 or 12 ...
Johan[/code]
DJD XTREEM
PostPosted: Thu Aug 19, 2004 10:32 am    Post subject: Reply with quote
$tiny
$noramclear
main:
   toggle portb.4
   wait 1
   goto main
Well the code works fine for me on a 90s2343 at Internal Oscilator.
I did set the fusebit for internal oscilator and corrected the speed to 1mhz..
STK500 Programmer
ISP Programmer
johanvdb
PostPosted: Thu Aug 19, 2004 11:10 am    Post subject: Reply with quote
Indeed ... on 2343 everything is fine. I'm talking tiny15 here ...
Oh ... now you talk aboutthe 2343 internal RC osc. have you ever tried a software UART with it? I can't get it to send something correctly, probably the RC osc is way of 1Mhz Wink
Johan
DJD XTREEM
PostPosted: Thu Aug 19, 2004 11:12 am    Post subject: Reply with quote
Well as far i know the 2343 can't be used for serial comunication.. it doesn't have a uart.. And as i know off not even controll for a software uart..
STK500 Programmer
ISP Programmer
johanvdb
PostPosted: Thu Aug 19, 2004 12:16 pm    Post subject: Reply with quote
Oh yes, you can:
[CODE]
$crystal = 1000000
open "COMB.3:2400,8,N,1" for output as #1
main:
toggle portb.4
print #1, "Hello World"
wait 1
goto main
[/CODE/]
The only problem seems to be the baudrate. A deviation from the clockspeed by 10% would mean a 10% deviation for the timings of the serial bitstream, that would hurt and definitely generate gibberish on the receiving terminal.
Has anybody experience setting up a software UART on a device with internal RC oscillator?
Johan
PostPosted: Tue Aug 31, 2004 10:23 pm    Post subject: Reply with quote
In version 1.11.7.4 waitms uses SBIW that is not supported in the tiny15. In the next beta , other asm is ued so waitms will worik with the tiny15.
But tiny15 is best to be programmed with asm.
