gmcge
Posted: Wed May 26, 2010 11:24 pm Post subject: Programming problem with STK200 |
Since upgrading from x.9.4 to x.9.8 I have had poor results trying to program an ATtiny261 using the dependable STK200 style ISP programmer.
If I "refresh" my fuse bits, about 50% of the time they are shown correct. If I program the flash then verify, I get differences and the differences are always at different locations in memory.
Ponyprog works fine and I am using XP. It sounds like a timing problem with the port but I have played around with the port delay and no difference could be detected.
Any ideas out there? Thank you..... |
Evert :-)
Posted: Thu May 27, 2010 8:13 am Post subject: |
Try increasing the delay of the programmer.
Options -> programmer -> Port delay _________________ www.evertdekker.com Bascom code vault |
gmcge
Posted: Thu May 27, 2010 4:49 pm Post subject: |
Hi Evert,
I did that. No difference could be observed. I am not sure what the units are in but I went right up to 500. I can only assume that represents 500ms?
Cheers,
Greg |
Plons
Joined: 24 May 2005 Posts: 435 Location: Hilversum - The Netherlands
gmcge
Posted: Sun May 30, 2010 6:18 pm Post subject: |
Hello Nard,
Nice write up on your web page. I will give it a try.
I just found it curious that the only thing I changed was the Bascom version.
Cheers,
Greg |
Plons
Posted: Sun May 30, 2010 7:47 pm Post subject: |
Quote: | .... that the only thing I changed .... |
If you read on that page my experience, just a different type of connector, you may come to the same conclusion as I did.
These PPPD's keep causing issues. As soon as you can afford a decent programmer: go for it
Nard _________________ Bascom AVR ver 2.0.8.6
Dragon-lair: http://www.aplomb.nl/TechStuff/Dragon/Dragon.html
"leef met vlag en wimpel, maar hou het simpel" |
