8*6 matrix keyboard
EKREMhbx
PostPosted: Thu Oct 13, 2005 9:35 am    Post subject: 8*6 matrix keyboard Reply with quote
hello
I want to make 8*6 matrix keyboard whi my m32
so
- config porta=output ' use 8 pin for column output
- config portc = input ' use 6 pin for row (portc 2 to portc 7) input
set portc
reset porta.1
waitms 10
lcd pinc
set porta
"loop
my program flow is below but I dont recognize wright button code
what is the wrong
I need help
thank you
DToolan
PostPosted: Fri Oct 14, 2005 12:04 am    Post subject: Reply with quote
I'm not sure what your exact problem is (I'm guessing english is not your native language), but the "SET" keyword is used for individual bit manipulation only. Although Bascom accepted your attempt to "SET" an entire port (and it compiled without error), it does not do that. You can't "SET" a byte or a port... only individual bits. The same is true for the keyword "RESET".
For your ports, you should use something like PortC = &HFF or PortA = &HFF. Your use of "Reset PortA.1" for a single bit is correct.
PostPosted: Fri Oct 14, 2005 6:42 pm    Post subject: Reply with quote
Try this one and look at the idea to keep the result "Memoire_clavier" variable, a loop into a loop.
Very low noisy keyboard and debounce perfect!
I use a 4 X 3 matrix keyboard where the user needs to "up" the key before the result is sending
The pin Portc.3 is use to drive a buzzer so take care about it
Function Key() As Byte
Local Cle As Byte , Ligne As Byte , Memoire_clavier As Byte
Encore3:
Ddrc = &B00000111 'configuration des ports colonnes
Portc = 7 'envoi 1 sur les 3 colonnes
Cle = Pinc 'lit les lignes
' Locate 6 , 1 : Lcd "cle ligne " ; Cle
Select Case Cle
Case 23 '31 without buzzer
Ligne = 1
Case 39
Ligne = 4 ' Ligne 2
Case 71
Ligne = 7
Case 135
Ligne = 10
Case Else
Goto Encore3
Waitms 50
'Wait 1
Ddrc = &B11110000 'configuration des ports lignes
Portc = 240
Cle = Pinc
' Locate 7 , 1 : Lcd "cle colonne " ; Cle
Memoire_clavier = Cle
Select Case Cle
Case 241
Key = Ligne + 1
Case 242
Key = Ligne + 2
Case 244
Key = Ligne + 3
Case Else
Goto Encore3
Cle = Pinc 'si la touche est toujours enfoncée on boucle
Loop Until Cle <> Memoire_clavier
Loop Until Key > 1
Cle = Lookup(key , Clavier)
Key = Cle
End Function
Clavier:
Data 0 , 0 , 1 , 2 , 3 , 4 , 5 , 6 , 7 , 8 , 9 , 100 , 0 , 200
Bon courage
EKREMhbx
PostPosted: Sat Oct 15, 2005 8:48 am    Post subject: 8*6 k&#305;eyboarsd for m32 Reply with quote
thank you for your answer
I want to how I acan adaptive your code
in my 8*6 matrix keyboard project (port c row*8and porta column*6)
in this time gor one column and one row enough for me.
regards
