Problem passing parameters to a subroutin in all versions
ario
PostPosted: Sun Sep 18, 2005 8:54 am    Post subject: Problem passing parameters to a subroutin in all versions Reply with quote
Hi
I have written sub a subroutin for test in bascom avr v1.11.7.3 to v1.11.7.9 but in all versions i cant pass any parametr such az values or references to a sub routin. my test program is here:
$regfile "m8def.dat"
Declare Sub Abc(byval A As Byte)
Abc 123
Sub Abc
Print A
End Sub
this program typically must print 123
but it will print 255!
cause the value is realy changed to 255 when it sent to the subroutin.
is that means i cant send any parameter to a subroutin in bascom?
Rolling Eyes
Thank for your replys.
Ario
Dibor
PostPosted: Sun Sep 18, 2005 9:44 am    Post subject: Reply with quote
Hi.
Checked with v.1.11.7.4
Print 123 !
Looks work.
View user's profile MSN Messenger
Dibor
PostPosted: Sun Sep 18, 2005 9:52 am    Post subject: Reply with quote
Hi
Maybe try tis :
Call Abc(123)
Sub Abc
Print A
End Sub
oe9vfj
Moderator
PostPosted: Sun Sep 18, 2005 11:31 am    Post subject: Reply with quote
HI,
You can pass parameter at this way.
Most problem at this topic are caused of to low stack settings.
Increase your stack sizes, especially those for Frame size.
Check also thread http://www.mcselec.com/forum/viewtopic.php?t=791&highlight=
regards Josef
DOS - File System for BASCOM-AVR on http://members.aon.at/voegel
PostPosted: Sun Sep 18, 2005 7:24 pm    Post subject: Reply with quote
hello,
First check your stact that is right.
how I do to work with Sub and function, it works very well, that is typically "Basic" law.
A procedure (SUB) must be declared in the following way:
Dim Pression as Integer, hours as byte 'declaration of the variables
Declare Sub Verification (byval Pression as Integer, hours as byte)
Pression = 255
Print Pression ‘ 255
Call Verification(pression) `call of the procedure
Print Pression ‘ 245
End 'end program attention the sub and function are written after this line!
Sub Verification(pression As Integer, heure as byte) ‘procedure
Pression = Pression - 10
Print Pression ‘imprime 245
Waitms 200 ' etc…
End Sub
I think You forgot that is underlined
JP
