Question for dimmable lighting controller.
Goto page Previous  1, 2
Rick-S
PostPosted: Sun Aug 16, 2009 7:11 pm    Post subject: Reply with quote
Well, thought I'd post just to keep anyone who may be interested in my on-going saga up to date. Very Happy
Here is a basic Schematic of the Zero-Cross and Triac output portions of my circuit.
The AVR I am currently using is on a development board but is your basic setup with a 16Mhz Crystal and Max232 for RS232 level conversions.
The 4 outputs are tied to portB 0 - 3
And the Zero-Cross is feeding into INT0 (portD.0 of Mega128)
The program below is the current variation. I finally got the delays working using a timer for the phase delay. I'm still trying to get a good grasp on the timers so there is probably a better way of doing this, but it is functioning.
As usual, any comments or suggestions for improvement or overhead reduction would be welcome.
I know the serial communication portion could probably be optimized. I haven't coded much in this area at all and got it to work as expected after several tries! Wink
$regfile = "m128def.dat"
$baud = 19200                                               ' use baud rate
$hwstack = 32                                               ' default use 32 for the hardware stack
$swstack = 10                                               ' default use 10 for the SW stack
$framesize = 40                                             ' default use 40 for the frame space
'$sim
'_______________________________________________________________________________
Config Portb = Output                                       'Triacs
Triac1 Alias Portb.0
Triac2 Alias Portb.1
Triac3 Alias Portb.2
Triac4 Alias Portb.3
Config Pind.0 = Input                                       'INT0
Dim T As Byte , T1 As Byte , T2 As Byte , T3 As Byte , T4 As Byte , Tn As Byte , Tt As Byte
Dim Nm As String * 1,
Dim Dig1 As Bit , Dig2 As Bit
Config Int0 = Rising                                        'Setup Int0
On Int0 Zero_cross
Enable Int0
Config Timer0 = Timer , Prescale = 8
On Ovf0 Phase_delay
Enable Ovf0
' Initialize variables
T = 1
Tn = 0
T1 = 10
T2 = 20
T3 = 32
T4 = 45
Print "Enter level as 3 digits"
Print "1st digit = Triac#"
Print "Next 2 digits = Level (05{Brightest} - 60{Dimmest})"
Print "Levels below 05 and above 58 may not fire the triac properly."
Print
'Main loop
   ' Check Serial for incoming data if there is process 1st digit
   If Ischarwaiting() = 1 Then
      If Tn = 0 Then
         Nm = Waitkey()
         Tn = Val(nm)
         ' Make sure Tn falls in range (1-4) if not, reset to zero
         If Tn < 1 Then Tn = 0
         If Tn > 4 Then Tn = 0
         ' If we have a valid Triac number, set Dig1 flag
         If Tn <> 0 Then Dig1 = 1
    ' Check Serial for incoming data if there is process 2nd digit
      ' Make sure we 1st have a valid triac number
      If Dig1 = 1 Then
        ' Then process the 10's place for our phase
        If Dig2 = 0 Then
          Nm = Waitkey()
          Tt = Val(nm)
          Tt = Tt * 10
          ' Set Digit 2 flag
          Dig2 = 1
    ' Check Serial for incoming data if there is process 3rd digit
      If Dig2 = 1 Then
        ' Reset Digit flags
        Dig1 = 0
        Dig2 = 0
        Nm = Waitkey()
        ' Create phase for triac based on Triac number (Tn)
        Select Case Tn
          Case 1:
            T1 = Val(nm)
            T1 = T1 + Tt
            Tn = 0
          Case 2:
            T2 = Val(nm)
            T2 = T2 + Tt
            Tn = 0
          Case 3:
            T3 = Val(nm)
            T3 = T3 + Tt
            Tn = 0
          Case 4:
            T4 = Val(nm)
            T4 = T4 + Tt
            Tn = 0
          Case Else:
            Tn = 0
        'Un comment to see the ouput numbers (will cause flicker)
        'Print "T1 " ; T1
        'Print "T2 " ; T2
        'Print "T3 " ; T3
        'Print "T4 " ; T4
   ' Fire triacs at phase points.
   If T = T1 Then Set Triac1
   If T = T2 Then Set Triac2
   If T = T3 Then Set Triac3
   If T = T4 Then Set Triac4
Phase_delay:
   Load Timer0 33
   Incr T
Zero_cross:
   Portb = 0
   Load Timer0 33
   T = 1
Rick
elephantshear
PostPosted: Fri Aug 21, 2009 8:24 pm    Post subject: Reply with quote
Hi Dad
COOL BEANS!
ex4
PostPosted: Fri Aug 21, 2009 10:43 pm    Post subject: Reply with quote
nice one Very Happy
as for the zero cross detector i use 10kohm resistor attached directly to INT0 pin, with 1N4002 diode as clamping diode. the voltage input is from a step down transformer, the transformer also act as psu for my dimmer circuit
that bidirectional optoisolator is rare in my local store,only the unidirectional one like 4N35
just about to post it in my site at
http://ex4-tech.id.or.id
View user's profile Visit poster's website AIM Address Yahoo Messenger
Rick-S
PostPosted: Sat Aug 22, 2009 12:45 am    Post subject: Reply with quote
LOL, looks like my son found his way into the forum while at school today. He's a Junior in High School this year and is taking a digital electronics class. Maybe he'll teach his old man something! Very Happy
ex4, is there any advantage to your method of zero cross VS my method? I was curious as I've seen it done both ways. I just opted for this because I had a couple of the PC814 isolators in my parts bin. Wink
BTW, nice website.
Rick
mako444
PostPosted: Sat Aug 22, 2009 1:14 am    Post subject: Reply with quote
Yes ex4, post your schematic here for sharing.
ex4
PostPosted: Sat Aug 22, 2009 5:21 am    Post subject: Reply with quote
@rick-s:
well for electricity reason : none,hehehe
for simplicity reason : 100% correct
thank you, got no job at the office, so build and post something on the net
here is the schematic
mako444
PostPosted: Sat Aug 22, 2009 10:45 pm    Post subject: Reply with quote
Very good, but you should not use a zener diode 5 volts after the 10k resistor on the microcontroller input, I think 16 volts directly at the port can damage the chip.
Which program you used to design the layout?
ex4
PostPosted: Sat Aug 22, 2009 11:53 pm    Post subject: Reply with quote
as far as i can tell, a pin on the avr will clamp the voltage to max 5V (Vcc). but the current need to be limited, that what 10k resistor are there. for the worse part, 10k can sense directly high voltage upto 220V AC, but for that such high voltage i recommend to use 1Mohm resistor, that should make the avr very safe, although it is in high voltage. High voltage with very minimum or without current at all is harmless,hehehehe Laughing Laughing
i use ExpressPCB, its free
Rick-S
PostPosted: Sun Aug 23, 2009 1:06 pm    Post subject: Reply with quote
Atmel's Datasheet AVR182 shows this can be done without regulation directly off the mains.
This is a clip from that datasheet showing an example circuit. Here is a link to the full datasheet.
The document does go along with what ex4 stated:
To protect the device from voltages above VCC and below GND, the AVR has internal
clamping diodes on the I/O pins (see Figure 1). The diodes are connected from the pins
to VCC and GND and keep all input signals within the AVR’s operating voltage (see Figure
2). Any voltage higher than VCC + 0.5V will be forced down to VCC + 0.5V (0.5V is the
voltage drop over the diode) and any voltage below GND - 0.5V will be forced up to
GND - 0.5V.
Even though the chips were designed with this in mind, I just feel nervous having voltage higher than 5vdc pumped into my controllers. Other than the fact the optoisolators were in my parts bin, that was my other reason for using them.
ex4
PostPosted: Sun Aug 23, 2009 4:22 pm    Post subject: Reply with quote
yup, thats why i tap it from a transformer rather than directly to the hot side
got freaking horrible experience with HVDC system long time ago
yup, that was a big wuuuuuuuuu Rolling Eyes
mako444
PostPosted: Mon Aug 24, 2009 1:20 am    Post subject: Reply with quote
good, I had this information, thank you.
Page 2 of 2
