kmont
Posted: Mon May 04, 2009 6:24 pm Post subject: Sitronix ST7529 LCD driver |
I have LCD 255x40 dots with ST7529. When it init according to the datasheet page 56 so to display anything is displayed. Can somebody advice me?
Thanks |
benoit
Posted: Mon May 04, 2009 7:24 pm Post subject: |
wich operational mode do you use ?
8 bit ,4 bit ,serial ?
if you use the 8 bit mode you can check if the controller as received the command otherwise not. |
kmont
Posted: Mon May 04, 2009 11:06 pm Post subject: |
I use serial 4line mod. |
benoit
Posted: Tue May 05, 2009 6:12 am Post subject: |
hello
may be it is just a problem of contrast level,
like the lcd contrast is digital , if you don t put the right value in register you display nothing.
, you can try to scan the VOLTCTRL register vith different value |
kmont
Posted: Tue May 05, 2009 2:32 pm Post subject: |
Maybe there is a problem in the format of DATA witch I sent them to displaying.
I send cmd &h30, cmd &h15 and data for colum, cmd &h75 and data for line, cmd &h5C for memory writeing mod and now I do not understand exactly what data should I send him. |
benoit
Posted: Tue May 05, 2009 3:19 pm Post subject: |
hi
could you post your code ? |
kmont
Posted: Tue May 05, 2009 6:09 pm Post subject: |
ok
benoit
Posted: Wed May 06, 2009 6:23 am Post subject: |
HI
i see you use the soft spi
may be you can try with command shiftout that you can better parameter
Tcmd &H81 <---- is command for contrast of the display
Tdat &H0A <- --- you can try several value for check the right one
Tdat &H05 <- --- you can try several value for check the right one |
kmont
Posted: Wed May 06, 2009 2:32 pm Post subject: |
Hi, I found the problem in the setting "Common scan (COMSCN) - Parameter Byte: 1 (BBH)" and the "Data scan direction (DATSDR) - Parameter Byte: 3 (BCH)" I try change the value and now it is OK.
thanks for advice. |
