Greece2001
Posted: Tue Apr 07, 2009 12:26 pm Post subject: Confusing Date ? |
Hi, I'm new to BASCOM and the" Date" command is absolutely confusing me.
Though I (think) I have configured everything correctly, Day and Month are not in the correct order.
Here are parts oy the code :
Config Date = DMY , Separator = . ' day.month.year format
Config Clock = User ' I'm Using the DS1307, works fine ...
dim StrTime As String * 8
Dim BWeekday As Byte
Dim StrWeekday As String * 10
Dim StrDate As String * 8
Dim Weekday As Byte
print #1 , "Date Test" '
_day = 07 ' set the internal vars to 7th of April 2009, today
_month = 04
_year = 09
print #1 , "Date$ = " ; Date$ ' This prints Date$ = 07/04/09 -> Date is okay, but Separator is wrong !
Bweekday = Dayofweek(_day)
print #1 , "_day=" ; _day ' This prints _day=4-> that should be 7 !
print #1 , "Bweekday:" ; bweekday ' This prints Bweekday:5 -> wrong !
Strweekday = Lookupstr(bweekday , Weekdays)
Strdate = Date(_day)
print #1 , "StrDate : " ; StrDate ' this prints StrDate : 04.07.09 -> Separator are okay, but Day / Month are in wrong order !
Print #1 , "Weekday-Number of Day=" ; _day ; " Month=" ; _month ; " Year=" ; _year ; " is " ; Bweekday ; " (" ; Date(_day) ; ") = " ; Strweekday ' -> Day / Month are wrong again
print #1 , "Date$ = " ; Date$ ' this prints Date$ = 7/04/09 -> Day / Month are okay, but Separator is wrong ...
By now I read all the examples, help-files, searched the forum for two days and either I'm too stupid to find my mistake or to understand how to use the Date and Date$ command or there is something else wrong.
So, please throw all you knowledge at me !
regards,
Greece2001 |
Evert :-)
Posted: Tue Apr 07, 2009 4:08 pm Post subject: |
Hi Greece,
What version of Bascom are you using and what type of Avr.
It's difficult to reproduce the problem with the incomplete code. _________________ www.evertdekker.com Bascom code vault |
Greece2001
Posted: Wed Apr 08, 2009 7:39 am Post subject: |
It is the 1.11.9.0 Demo I got from a friend, the µC ist a mega128.
regards,
Greece2001 |
oe9vfj
Joined: 17 Jun 2004 Posts: 269 Location: Austria, Hard
Posted: Wed Apr 08, 2009 8:35 am Post subject: |
I tested your code and it works all well. I got the estimated result.
May be your stack-settings are to low. _________________ regards Josef
DOS - File System for BASCOM-AVR on http://members.aon.at/voegel |
Greece2001
Posted: Wed Apr 08, 2009 9:22 am Post subject: |
Strange, very strange. Here the definition part of the program and I reduced the program to the date / time - thing, so much of the config-stuff could be left out. The RTC is running fine, keeping time and everthing.
Code: | $regfile = "m128def.dat" ' used device Mega128
$lib "ds1307clock.lib"
$lib "i2c_twi.lbx" ' we do not use software emulated I2C but the TWI
$hwstack = 30 ' stack depth
$swstack = 30
$crystal = 8000000
Config Timer1 = Timer , Prescale = 1024
Config Timer3 = Timer , Prescale = 256
Config Scl = Portd.0
Config Sda = Portd.1
Config 1wire = Porte.2
$baud1 = 19200
Config Com2 = Dummy , Synchrone = 0 , Parity = None , Stopbits = 1 , Databits = 8 , Clockpol = 0
Open "com2:" For Binary As #1
Config Lcdpin = Pin , Db4 = Portb.0 , Db5 = Portb.1 , Db6 = Portb.2 , Db7 = Portb.3 , E = Portb.4 , Rs = Portb.5
Config Lcd = 20 * 4
Config Adc = Single , Prescaler = Auto , Reference = Internal ' config, Internal (2.56V) Vref is used
Config Clock = User |
