MMC with UART
meisamb
PostPosted: Thu Feb 12, 2009 8:40 am    Post subject: MMC with UART Reply with quote
in my project, i have used SPI protocol in another connection, So can i connect mmc in Uart mode?
if i can please help me in schematic...
oe9vfj
Moderator
PostPosted: Thu Feb 12, 2009 11:07 am    Post subject: Reply with quote
You can not use MMC or SD Cards in UART-Mode, because MMC/SD need SPI.
But in the driver there is also a build-in Soft-SPI. With them you can use four other pin (with normal I/O adress, not over &H60) to attache the Card.
Please check the File config_MMC_bas. Here you find information how to change to Soft-SPI and of course you have to set your pins.
regards Josef
meisamb
PostPosted: Thu Feb 12, 2009 5:25 pm    Post subject: Reply with quote
Thanks Josef
I will try..
