mmarlette
Posted: Tue Feb 10, 2009 5:06 am Post subject: 1wire multi bus |
Version 1.11.9.3
ATmega128
No Config 1wire command used.
The below function is called from a main routine with the bus number passed to it as 1 or 2.
My test case is simple.
No sensor plug in, both buses report no sensor, CORRECT.
Sensor in bus 1 ONLY, BOTH buses reports &h10, WRONG s/b only on bus 1.
Move sensor to bus 2 ONLY, and reports &h10 on bus 2, 0 on one. CORRECT.
Read in the Config 1Wire extended but that doesn't seem to work either.
At a loss here......I removed some of the function code so that it is easier to read. IE: parameter return, etc....
function DS18S20_FindDevice(byval byt_BusNumber as byte) as byte
local byt_tempDSF as Byte 'temp var for FUNCTION return value
Select Case byt_BusNumber
Case 1:
1wreset pina,0
print #2, "Bus 1=";
DSid1(1) = 1wsearchfirst(pina,0) 'if zero returned, no devices
print #2, DSid1(1) ;
Case 2:
1wreset pina,1
print #2, "Bus 2=";
DSid2(1) = 1wsearchfirst(Pina,1) 'if zero returned, no devices
print #2, DSid2(1);
End SELECT
print #2, " Exit"
end function |
mmarlette
Posted: Tue Feb 10, 2009 7:25 pm Post subject: |
Ok, simplified the problematic code so I can post it here. Same results.
No sensor in bus1 or bus2, program reports 0 on both buses, CORRECT.
Plug Sensor in to Bus1, press reset on STK500.....
Program reports the same device on both ports. WRONG!!!!!!
Move sensor from bus1 to bus2, press rest on STK500.
Program reports no sensor on bus1, sensor on bus2. CORRECT!
Here is the single module code, minus the serial code which does nothing more than setup the COM2 of the ATmega128 to 115.2, hardware handshake.
Any ideas????
Const 1W_version = " v1.00"
Const True = 1
Const False = 0
Const Debugflag = true 'turn off/on serial debug monitor
Const bit0 = 1
Const bit1 = 2
Const bit2 = 4
Const bit3 = 8
Const bit4 = &h10
Const bit5 = &h20
Const bit6 = &h40
Const bit7 = &h80
'Version Date Description
' V1.00 2/10/2009 1. Genesis.
'Hardware Connections:
'Port A.0 = 1 Wire Comm Channel #1
'Port A.1 = 1 Wire Comm Channel #2
'Port D.2 = RXD \ On STK501
'Port D.3 = TXD /
'Port C.0 = RTS\ On STK501
'Port C.1 = CTS/
'Port C.2 = 1 Wire Comm Channel #3
$regfile = "m128def.dat"
$hwstack = 250 ' over ride default of 32 for the hardware stack
$swstack = 250 ' over ride default of 8 for the SW stack
$framesize = 250 ' over ride default of 24 for the frame space
$crystal = 7372800 'using PS2 Xtal, full swing mode or
'Main Variable Declaration Section
Dim DSid1( As Byte 'Dallas ID 64 bits incl CRC
Dim DSid2( As Byte 'Dallas ID 64 bits incl CRC
'* Progam Startup
$include "..\..\..\commonroutines\Serial_config.bas"
#if Debugflag
Call Serial_debugbanner(1W_version)
Call Serial_bell
#endif '
'* MAIN LOOP *
'Initialize 1-Wire Devices now....
1wreset pina,0 '1Wire bus #1 pin
print #2, "Bus 1=";
waitms 100
print #2, DSid1(1)
1wreset pina,1 '1Wire bus #1 pin
print #2, "Bus 2=";
waitms 100
print #2, DSid2(1)
'wait forever, press reset
$include "..\..\..\commonroutines\Serial.bas" |
Posted: Tue Feb 10, 2009 7:52 pm Post subject: |
I don't have real 1W hardware here, so what i'm suggest is only theoretically.
Try reset the first bus before using the second bus.
print #2, "Bus 1=";
waitms 100
print #2, DSid1(1)
1wreset pina,0 '<=============
print #2, "Bus 2=";
waitms 100
print #2, DSid2(1)
1wreset pina,1 '<=============
mmarlette
Posted: Tue Feb 10, 2009 8:21 pm Post subject: |
Good idea, but the results are the same. |
mmarlette
Posted: Tue Feb 10, 2009 8:34 pm Post subject: |
I also tried PortE and Port A and all combinations ther eof.
Results are consistent and the same. |
Posted: Tue Feb 10, 2009 9:30 pm Post subject: |
Next try,
Make the first port the "original" 1w (the one with config 1wire=...) and the second as it is now.
In the beginning of Bascom there was only the 1W commands in combination with the "Config 1wire =" , therefore only 1 bus was possible. In a later stage Mark has add the option for the port, pin option for the second bus.
In the helpfile he also calls it "'use this port and pin for the second device", it's how you read it but it's possible that the first bus must be the original one.
Config 1wire = Porta.0
1wreset '1Wire bus #1 pin
print #2, "Bus 1=";
waitms 100
DSid1(1) = 1wsearchfirst() 'if zero returned, no devices
print #2, DSid1(1)
print #2, "Bus 2=";
waitms 100
print #2, DSid2(1)
mmarlette
Posted: Tue Feb 10, 2009 10:12 pm Post subject: |
use of the config 1wire command per your example yields the same results.
No go yet. |
mmarlette
Posted: Tue Feb 10, 2009 10:31 pm Post subject: |
Tried an example right out of the HELPfile and it produces different results with NO SENSOR on the one wire bus.
This si the output for the code below. I would expect both to be the same with no sensor installed.
0000000000000000
FFFFFFFFFFFFFFFF
dim i as Byte
dim a as Byte
For I = 0 To 1 'for pin 0-1
1wreset Pina , I
1wwrite &H33 , 1 , Pina , I
DSid1(1) = 1wread(8 , Pina , I)
For A = 1 To 8
Print #2, Hex(dsid1(a));
Print #2, " "
Next |
Posted: Tue Feb 10, 2009 11:10 pm Post subject: |
This might not be relevant, but I would ask why you need two pins assigned to different 1 wire busses ? The Dallas chips are individually readable, so just put them both on the same bus.
While I agree the code you have should separately work on each pin, and there is a problem if it does not, maybe you could just sidestep the problem. _________________ Adrian Jansen
mmarlette
Posted: Tue Feb 10, 2009 11:24 pm Post subject: |
Adrian,
As you can place multiple sensors on the bus, the problem is identifying which temperature sensor is where. The system I am creating is an energy managment system that calculates the heat loss of your house and controls the 20KW dual fuel furnace based upon input from sensors. The sensors being the DS18S20 digital thermometers. Inside, outside, room, duct temp above power resistors to close the desired temp loop, etc. There is NO margin for error.
Unless you have some sort of fancy way of cataloging the sensor ROM code to a physical location you could get the sensor swapped as you physically don't know which one is which.
You would have to have some sort of system maintenance menu that you would add each sensor to the bus, read it's ID, save it to a location to denote physical location, then add the next sensor until all sensors ID are associated with a physical location. Not impossible. Just seems like it would be easier to have a port dedicated to sensors and only have one temp sensor on the bus. You could add other devices, if needed.
Using an ATmega128, has many ports....
A better idea??? |
Posted: Tue Feb 10, 2009 11:49 pm Post subject: |
Hmm, I see your point. But if its a fixed physical layout, with no possibility the sensors can be swapped except by someone who also keeps the physical map updated, then I dont see it as a big issue. Can you put incompatible connectors on each sensor, so they cant be swapped ? Eg use a 25 pin connector, but different single pins for each sensor at each location. Even with multiple busses, you still need to keep the map updated, although I agree you get a chance to check that the correct sensor ID is on the right bus.
At least you have an ID assigned to each sensor. Back in the old days I did tunnel kiln monitoring with just thermocouples ( 100 or so ). Keeping track of which thermocouple was where was fun, especially when the night shift would swap them ( and their wiring ) from kiln to kiln. _________________ Adrian Jansen
mmarlette
Posted: Wed Feb 11, 2009 12:00 am Post subject: |
Adrian,
I would not have a problem keeping the straight but remember, no offense meant here, you are dealing with plumbers and electricians. My experience is that it will get messed up. Forgot to add that there is also a heat pump in the system as well.
Any sensor can go anywhere and the plugs are all the same. We do not wan t to have separate part numbers for each sensor when they are the same. Plug a sensor in this location, it is xxxxx sensor now. They can handle that.
I believe this call is broken. I have sent in bug reports with almost NO response from the makers of Bascom, which I am not even sure who that is. Or fleet of people.
I have many hours in to this task, trying to find a work around.
I suppose I could pay for support but am a bit concerned that if I do pay that the response will be yep, problem noted, you are the only one, so it is not a real high priority to repair it. I can see their point but that doesn't help me.
Hmmmmm, what next..... |
Posted: Wed Feb 11, 2009 1:04 am Post subject: |
I always had good response from Mark Alberts, the designer of Bascom, on any support request.
Yah I know about non-tech people handling installations.
I cant see any easy way of associating each cable end with a sensor, unless you can somehow ID the end, and be sure that end has a particular sensor ID attached. In fact, your problem is not reading the sensor IDs, its making sure some sensor is attached at a specific cable end location. I am out of time, but maybe you can think about this a bit more.
Edit:
One more thought, can you use some other port pins on the processor to gate the 1 wire signals through a selector switch like a 4051. Then you just select up which star bus line you pass the 1 wire signal through. _________________ Adrian Jansen
