fast pwm
stef
PostPosted: Sun Jan 11, 2009 3:19 pm    Post subject: fast pwm Reply with quote
hello
I have a problem i was doing some small program in bascom with pwm.
Now my problem is that the output which i check with my osciloscope isn't equal to the one that i calculated. In the datasheet of the atmega32 i read there was something like a fast pwm how can i write it in bascom coes cant find a thing bout it in the help?
thx for help
mattcro
PostPosted: Sun Jan 11, 2009 7:10 pm    Post subject: Reply with quote
Bascom configures Timer1 in Phase Correct PWM when you specify PWM mode like this:
'Init Timer1 for PWM
'this does freq+phase correct PWM (WGM Mode 1)
Config Timer1 = Pwm , Pwm = 8 , Compare A Pwm = Clear Down , Compare B Pwm = Clear Down , Prescale = 256
To use Fast PWM, you can just do this:
'Init Timer1 for Phase Correct PWM
'now change mode to fast pwm (WGM Mode 5)
set TCCR1b.wgm12
That will basically double the output frequency relative to the default Phase Correct mode. You set the duty cycle using Pwm1a in the normal way.
It's similar for Timer0:
Config Timer0 = pwm , compare a pwm = clear down , compare b pwm = clear down , Prescale = 8
'change mode to Fast PWM (WGM mode 3)
set tccr0.wgm01
The PWM modes are documented in the Modes Of Operation section under Timer0/1 in the datasheet. Look for Waveform Generation Mode.
BascomAVR 2.0.8.5
stef
PostPosted: Tue Jan 13, 2009 7:30 pm    Post subject: Reply with quote
hello
thanks this helps me aloth.
i apreciate your help and time Smile
grtz
cowboyrx
PostPosted: Mon Feb 09, 2009 5:02 pm    Post subject: Reply with quote
Is there an example available or a possibility to generate a sine wave (with steps) using the fast PWM feature of mega48?
PostPosted: Tue Feb 10, 2009 4:02 am    Post subject: Reply with quote
@ cowboyrx
You might get some ideas from:
http://evertdekker.com/Joomla/index.php?option=com_content&task=view&id=60&Itemid=99
Adrian Jansen
cowboyrx
PostPosted: Tue Feb 10, 2009 3:38 pm    Post subject: Reply with quote
AdrianJ wrote:
@ cowboyrx
This is a fast pwm example provided by Atmel. Should work on mega48, but is in asm not Bascom. It compiles ok in AVR studio, but can't run it. It keeps saying 'waiting for PLL' Sad
http://www.avrfreaks.net/index.php?module=Freaks%20Tools&func=viewItem&item_id=498
PostPosted: Tue Feb 10, 2009 10:39 pm    Post subject: Reply with quote
The AtTiny26 used in that example has an internal PLL capable of running at 64 MHz, and driving the timer1 counter for the fast PWM. AFAIK the AtMega48 does not have this PLL. You can still use PWM, but not with the high frequency clock source.
Adrian Jansen
