AVR-DOS - Read/Write Double variables
Post new topic   Reply to topic    www.mcselec.com Forum Index -> AVR-DOS
tomi
PostPosted: Sun Jan 06, 2008 2:18 am    Post subject: AVR-DOS - Read/Write Double variables Reply with quote
over little debuging we found problem when you want try to read/write DOUBLE variables into text files, for example with this code:
Dim dbl_var as Double
Open "test.txt" For Output As #3
   Write #3 , dbl_var
Close #3
Open "test.txt" For Input As #3
  Input #3 , dbl_var
Close #3
You get compile errors about missing some labels [_dbl_bin2asc]. If you get this type of errors, workaround is simple:
- open avr-dos.lbx file
- search for:
[_FileWriteDecDouble]
$EXTERNAL _FileWrite_StrBuf
and replace with:
$EXTERNAL _FileWrite_StrBuf , _dbl_bin2asc
- next search for:
[_FileReadDecDouble]
$EXTERNAL _FileReadString
and replace with:
$EXTERNAL _FileReadString, _Dbl_ASC2Bin
- save file
Now when you compile program it should compile without errors.
In some situation you can get also error about missing labe [_DIV16], solution for this is simple, just place in your main program this directive :
$external _div16
Best regards,
/Tomi
taroosheh
PostPosted: Sun Sep 28, 2008 7:53 pm    Post subject: hi Reply with quote
in AVR-DOS the write command not work properly
you can use put and get commands that these are more general and work very well
try this path:
http://www.electrorc.blogfa.com
for en:
http://electrorc-en.blogspot.com
View user's profile Yahoo Messenger
Post new topic   Reply to topic    www.mcselec.com Forum Index -> AVR-DOS All times are GMT + 1 Hour
